It’s time for me to sell my beloved GTR as I’m getting a deposit together for a house. I’ve spent over $25,000 on parts, you’ll be hard pressed to find a cleaner 33 GTR.
Car was tuned by JEM and made 297kw on BP 98.
Price is 28,000 ONO – Sorry not interested in swaps or trades
Car is located in Canberra
I will be putting photos up over the weekend
Any queries you can contact me on 0 Four 23492200
Specs are as follows, chances are that I've missed things:
Engine – Rebuilt November 2012 – Can provide majority of receipts
Engine block was completely machined (decked, acid dipped and welsh plugs were replaced, crank balanced, bores honed, oil galleries drilled out, x-rayed for cracks ect)
New CP forged pistons with 9:1 compression
I-beam Forged Rods
N1 Oil Pump with Reimax billet oil pump gear
Trust Oil Sump Baffle with extended oil pickup
New Alternator
All seals and gaskets were replaced with OEM items, with the exception of a cosmetic metal head gasket.
All new OEM heater hoses – Over $700 worth of hoses
New Clutch Fan
ATI 1000HP Harmonic Balancer
Greedy 19-Row Oil Cooler with Thermostat and Oil filter relocation kit
New oil pressure sender unit
Head has been serviced, with new OEM camshafts installed
Nismo Engine and Gearbox mounts
New Thermostat
Turbo/Exhaust
Garret 2860-7’s with HKS actuators
X-Force Dump Pipes
HKS Front Pipes and CAT
3.5 Inch Custom Exhaust
Driveline
Gearbox was refreshed with new syncros at Award and Diff in Sydney in February 2015 new 4th gear set installed November 2014, serviced with Redline Lightweight Shockproof
Transfer case was inspected by Award and Diff and serviced with new transfer case fluid. ATESSA actuator piston has been modified to allow faster engagement of the front wheels.
V-spec Electronic Diff was serviced with new fluids
Nismo Coppermix Twin-Plate Clutch
Ignition/CPU
Spitfire Coilpacks
New coilpack harness
Apexi Power FC with Hand controller
Greedy Profec B Electronic boost controller with hi/low boost settings
Tarzan G-Box Installed – Replaces stock G-force sensor. (http://www.speedhunters.com/2012/06/the-gt-r-gets-tarzan-ed/)
Viper Alarm system with immobiliser, tilt sensor, glass break sensor and shock sensor
Fuel
Walbro 240 hiflow fuel pump
Flow tested injectors
Suspension/Handling/Braking
Tien Monoflex Coilovers
Nismo ball joints
New tension Rods and Universal links
Cv Joints replaced
Suspension calibrated by Capital Steering and Suspension in Canberra
Michelin Pilot Sport 3 – Installed 10,000kms Ago
Nagisa Auto strut braces – Attach to front quarter panel
New DBA T3 Rotors and Project Mu Pads with DOT 4.1 brake fluid
Interior
Reinforced driver’s seat – Frame was reinforced with thicker cold-rolled steel. In addition the seat and backrest foam was also replaced.
Nismo Centre Gauges
Genuine Nissan Floor mats
Exterior
Series 3 Xenon Headlights
Nismo Clear Front Indicators
Nismo Clear Side Indicators
OEM Series 3 Front Lip with Brake Ducts
Series 3 Bonnet Lip and N1 Vents
Nismo Wing Caps (Carbon)
Nismo Weathershields
Other things
New Battery
Serviced with Motul Fluids ever 5,000kms
I have spare parts including stock edu and Quest LED Tail-lights
Hey mate, did you have the motor built, who was it built by and what boost pressure are you currently running through it ? Also is it still running the standard fuel system i.e injectors, rail, pressure reg etc ? Is it neat in the body, has it ever had a hit, paint etc ?
Bump - For everyone thats been asking, yes, this car will pass rego. New tires, legal height and even legal window tint.
  • 4 weeks later...
Been watching your car Since you advertised it on Carsales.
Hope you got close to what you were after, one damn nice car.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
