Hi guys,
Been driving my 33 for a while now and it has been faultless. However the other week I was cruising at 60 and it felt like the engine power had dramatically decreased..almost cut off. I tried to push down the accelerator harder but the revs were struggling to increase and the car was in a jerky motion. I pulled over to the side and the idle was fluctuating from say 200, where the car would almost die, to 1200 rpm. After a few mins the care felt okay to drive again, but not 100%. Since then, if I don't use boost then the car will drive okay. Once I hit boost hard (1st gear pulls) and while im still in boost, it sounds like the turbo is whistling but the car isn't accelerating much. Then after this short spurt of boost the car will feel sluggish, jerky, and very minimal engine response from the accelerator. The car will end up regaining some power after a couple of minutes but not fully.
Prior to this happening I had an aftermarket bov which I had to change back to factory. I thought it could be the issue so I changed it back to the aftermarket one but the car still acts the same. Fuel pump is a wallbro 255 and is fine...still primes when turning the ignition to ON. I'm still thinking it's some kind of fuel related issue. Maybe turbo has had it? Care to shed some light guys? Thanks for the help.
EDIT: i have yellowjackets with the standard plugs that rb25dets use.. replaced the plugs only 2000kms ago
Edited by BlackLine33
You may have a boost leak, split line or something. It could explain why it's OK until it sees pressure then goes funny. I had one a couple year back and it drove fine until it saw boost and would rub terrible. Are you getting any black/dark smoke out the back when it does it? Mine turned out to be a broken rubber plug which was being used to block vacuum hose attachment off the comp housing of an OP6 turbo. Put a new plug on it, problem gone.
Edited by FordyR31
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
