VB cans work, bed in easily. I tried Four XXXX but got all crossed up and ended up in the pissed n' broke/piston broke club!!!!
Real answer - It depends on your power goals vs your budget. Standard takes more of a hammering than we all thought they would. Then theres plenty of aftermarket and none have a bad reputation, as somebody said its not the product its the build you get that is the defining limit.
Sort of good point. The reason I went with Tomei pistons is because I talked to someone that put 100k (over 10years) on an engine with them - had some track work too.
He had standard rods with tomei bolts. Rod ended up giving up.
So when i looked into them they seemed like the best option for a RB26. So far 12,000km on with them. Hopefully another 80+ to go.
I reckon anything Jap, 9 times out of 10 would have to be the best or close to it, they usually make/build as we know, great engines , so makes sense they will deliver an outstanding piston ( Tomei ) to put in there own designed/built engines.. :ph34r:
Edited by AngryRB
INB4 piggaz gets here and starts talking about jap cams and valve springs.
Edited by iruvyouskyrine
Here is a story.
Once upon a time.....
There is a bloke in Victoria from Pacific Engine Parts who supplied the piston rings Fred Gibson used for the Group A GTR's. Knows a thing or two he does. If you want a good piston get good rings and built the motor properly. We do good engineering in Australia too, you know. Or atleast did before the Chinese, the mining boom and the wrong headed notion that if it is from overseas it must be better destroyed all our manufacturing industries.
Oi how shit are those jap springs and cams!
Seriously though, they re shit
I'm not disagreeing haha, I just know he won't stand for someone saying how good tomei type b poncams are and the quality of Japanese valve springs. Really gets his goat :P
He isn't the only one with the same story, but basically it goes along the lines of fitted Japanese valve springs (tomei in mine, hks in his) neither had enough seat pressure and caused miss fires in his due to float, mine were checked before being fitted, both replaced with super tech and now fine
The real answer is..if you have to ask on a forum, you probally don;t need them...maybe a bit harsh..but true
cheers
darren
So researching and checking ask your facts before pulling the trigger means you don't need them?
Guess all the cheque book racers who get 1000hp plus built lambos and the likes don't actual need after market pistons in that case?
Such a stupid logic some people have, not like I asked do I need after market pistons for 300+kw or something.
one of my tomei springs broke and wrecked my engine :(
Further make this a discussion about valve trains*
Not sure if true, but ive heard that valve springs can be damaged if motor is flogged cold? I cant imagine a mechanic in Japan working for Mines, to say no no no, don't use tomei, use only supertech!! lol... just saying... :ph34r:
Read it on Oztrack.com.au , there's other causes like bouncing off the limiter, overheating etc..
Edited by AngryRB
Pretty much..
I assume that you want way over 1000hp at the crank....to even ask the question..so my assumption is that you don't need them if you have to ask...
Ill put it to you that unless you done over 1000hp at the crank ..before ...that you will run into the same sort of probs that workshops that have done this have encountered..and that
you stockpile blocks and practice nuking cheaper parts first because the rods and pistons , even cheap chinese shit wont be your problem...
if your a chequebook racer, well just go sign the cheques, if you need to double check said workshops info , you need to find another workshop
sorry if i offend you
cheers
darren
Pretty much..
cheers
darren
Nope aiming for 400kw with a little room to grow. Why not upgrade pistons if the block will be stripped in the build anyway?
Get my reason?
And no not offended just find sometimes people are rude on this forum to legitimate threads or questions for no reason and it doesn't help the community grow.
Not saying yours was but it could be perceived like that
Edited by anon32
Well just some random thoughts on general SAU stuff.
Try and avoid F&F/Facebook language. Whatever the merits (or otherwise) of such language a considered, well put together post to start a thread will get a much better response than something that sounds like it was written by a bored, trolling teenager in 30 seconds. (Not saying yours was quite that bad.)
If you had have asked for a piston recommendation for a 400kW build you would have got no end of people saying Tomei/CP/JE/Nitto etc etc. All of which are fine.
If you had have asked what attributes of a piston may be important on an RB you may have got a different answer again.
TL:DR. When you start a thread try not to sound like a teenager, try and make it sound considered, include what you know and understand that aside from just answering (or not) your question it may well provide information for someone else at another time.
Lastly if you think I should shove my post up my ar$e that is probably fair enough.
  • Like 2
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
