Here's the valve Brett asked as to what treatment you gave.
However you mentioned the filter retains oil so that tends to rule out the filter's drain back valve as well as this blocked filter by-pass valve.
Your problem seems more that the pump has to re-prime after a certain time has elapsed.
Can you go into more detail about the N1 oil pump build.
You'd be aware they have no non-return valve as such, simply relying on the porting and it is possible to install the gears facing the wrong way, which may upset the port clearances???
Now having said all that, 2-seconds isn't very long for the oil to pump up, but it certainly is annoying.
Hey Jiffo thanks for that.
I bought an OEM N1 oil pump from Nissan. I didn't modify the pump at all and using the original gears... I also didn't preprime the pump when I bought it because the Nissan guy said its already primed and it had caps on it which was holding in some sort of lubricant.
It terms of what Brett was referring to. I didn't block that valve. Do you recommend I block it?
It just hurts to hear my newly built engine rattle on startup lol. :(
No idea why Nissan fitted that valve as the oil filter has its own by-pass valve to allow for a blocked filter.
It's not on all Rb30's either. From my 3-blocks only 1-had the blocked filter valve, the others had a tapered plug hammered in.
It should have been removed when your block was originally tanked and cleaned.
Would be worth removing the filter and having a close look at whatever's in there.
  • Like 1
  • 5 years later...
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
