So I've just finished putting 550cc nismo injectors, Z32 AFM, Hypergear highflow and a Power FC into my 1996 R33 GTST.
Now the only problem is that the car wont idle? As soon as it starts it dies, unless i control the revs manually.
I've gone through on the hand controller and turned the boost control kit off, I've set the injector latency correction and I've selected that it's running a Z32.
Any help would be greatly appreciated thank you.
https://www.sau.com.au/forums/topic/457232-power-fc-help/
set the injectors to 450 and try that, it will all be changed once the tuner plays with it anyway.
sometimes they go a bit lean with the full 550 on the std map.
other thing is the orings could be weeping and over fueling.. check for black smoke instantly smoke after startup
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546145
Been playing around all afternoon and found a few things,
A hose that goes to the AAC was blocked that has now been cleared, still wouldn't start so I've pulled a spark plug out and from trying to start the car so many times I've fouled the plugs.
Would this not allow the car to start what so ever?
Edited by aMAYESing
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546181
adjusting latency settings won't be enough your injectors are bigger than standard you'll need to scale them back as you'll be over fuelling if you leave stocks ecu settings hence your wet plugs. Make sure you're o2 feedback function is switched on on the handset regardless of ignition and fuel values your car should still remain idling regardless of what inputs are selected in the idle section of the map. It's the only time the power fc reads the factory o2 sensors and does it only to stabilize idle and cruise throttle inputs I recommend you have a proper wideband fitted so you know what's going on otherwise you're just guessing and that's dangerous I wouldn't put a computer in a car without a wideband already fitted
Edited by mr skidz
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546203
I had the same issue when i dropped 1000ccs in, I had done the injector latency corrections etc and it wouldn't idle. I found out it was running mega lean and I had to add more fuel over the course of the map. I have to go into ignition/injector correction every time I want to start the car and adjust the injector side so it runs right. Been driving around for 3 months like this and it drives pretty well, doesn't ping, run rich or knock its head off under load I think its about finding the sweet spot. Obviously its not as good as a full tune but its got me out and about for some more RandD to go back to the drawing board with before the real tune.
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546209
but he's injectors are wet that can only be fuel so he's running rich he needs to back the scaling down Edited by mr skidz
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546216
Injectors have been set to 67.5% with .18ms of lag to compensate as per paulr33's Power FC FAQ.
I have a wideband currently installed, but I cannot get the car to start so that's irrelevant atm. Just want to get the car running and know that it's all good before I leave it with a new tuner.
The only thing i can imagine the problem to be is the spark plugs, they're caked.
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546235
Sorry I only skim read the thread. If thats the case then back off some of the fuel until it starts and idles, then check it with your wideband once its ideling by its self and work off that. I dont have a wideband but I used gopro footage and a good ear to get mine to where it is atm. Just be careful as you can also cause damage if you go too far and dont have a understanding whats happening when pressing buttons.
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546258
Make sure power fc is reset before you put your settings in if you've just altered it from when you received it the engine cranking fuel values might be too high from the previous tune also making your plugs wet or could also be your cold start values which also play a part when your engine is cold.
the two could be too high, best is to reset then put your values in.
on standard settings it should get your car kicked over but make sure 02 feedback function is switched on so the o2 sensors can stabilize your idol hope this helps
Edited by mr skidz
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7546931
Thanks for the replies, put new plugs in today and had a general look over the engine to find a hose to the AAC was blocked. Unblocked the hose and with a bit of encouragement the car started and was running perfectly, got through the learning procedure without any dramas. Won't be driven until it's to the tuners in a few weeks.
Does anyone have a rough idea on how much would be a reasonable price for a full custom dyno tune? I've been quoted $8-900 and to me that just seems plain ridiculous.
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7547174
if plugs are wet i reckon the lower oring is nicked on the injectors or you pulled the injectors out of the rail whilst the rail was in the car and all the fuel emptied into the cylinders.
Try start it with your foot to the floor, will take upto 1min of cranking before its starts.
https://www.sau.com.au/forums/topic/457232-power-fc-help/#findComment-7547584
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
