This car does not have stock wheels.
The grill has a GTR badge.
The front bar is not an original standard
front bar.
Just curious what color is the car you
are talking about.
Assumption is the mother of many mistakes.
Your reply is a bit smug please feel free
to PM me with any constuctive comments if
u know this car so I can avoid making a
mistake.
Richard
  • Replies 89
Are you sure the white smoke just wasn't steam coming from the cold exhaust in cold weather? Water condensation evaporates when the exhaust heats up and steam rises, that old trick? Maybe the guy wasn't talking out his ass because they would be more likely to do this when washed/rained on.
If it was "wafting vertically" and "diffuse and light" then it could be steam. Next time you start it from cold, watch the exhaust and "feel" the smoke. If it is steam it will condense on your hand and you will have a dirty wet palm.
I don't think it was steam. Although I didnt hold my hand above it to check (should have).
It did seem to go away though after a few decent revs... The engine reved out nicely. No strange sounds.
I'll let u guys know how the mech/comp test goes tommorrow. That and the REVS check are the last 2 hurdles the owner has accepted my offer.
I will loose the $600 from deposit and mech check but figure thats a small price to pay on avoiding an expensive mistake, if the mech check fails.
I will need to fix that door and the rear panel next to it though. Not a roadworthy issue but I cant stand things not straight.
Despite the fact it was probrably a little silly making a decision so quickly - I wouldn't stress too much. Chances are the car's still half decent. If it's had accident history that doesn't matter greatly either - as long as it's been repaired correctly.
Correct, but make sure the parts are correct items too.. i dont consider a fibreglass $300 copy of a bar appropriate for a gtr that should have a plastic bar that is worth $1700. And thats just an example.
If in doubt, get someone from the forum who knows more to go with you.
This sounds really sus, like its been smashed in the front end. look at the bolts fastening the front quater panels. Also look at any other bolts that fasten panels to see if they are new or are freshly painted over. Loof at the fmic mounts, pipe hose clamps etc. Have a look down the side of the car to see for straightness. check the hose clamps and fastners etc on the engine too for replaced parts. Be very very careful mate! good luck, hope you can find a good GT-R! :)
-rb25
N/A you would do me a great service by PM ing me
all details so I can work out if it is indeed the very
same car.
You continue to leave clues and abstract comments
without helping someone out.
Is this too much to ask, or are there other issues
at play here?
If PM is no good feel free to email
[email protected]
If u are thinking that I should have enough info
to go on with you are wrong I need better
evidence so I would appreciate some help.
Thats not an unreasonable request is it?
White smoke can mean water is in the exhuast, also meaning steam.
It can also mean there could be a water leak into the engine from the water system, or water in the oil.
Get it checked out and decide after that, it shouldn't be of any great loss to you either way it goes.
I was watching some doco on National Geographic, and for the smoke that comes out of the back of those stunt planes, or the formation planes at the air shows, they said they dropped oil on the exhaust and the heat from the exhaust causes the white smoke? So don't know if that applies to a car, with an oil leak on a hot exhaust? Altho, if it happens as soon as you turn it on then goes away when it gets warm, that contradicts that idea a bit doesn't it?? Oh well :D
Good luck with the buy. I bought a car in japan a few months back, description was good and pics look ok, just hoping she's alright when it gets here. Hard to tell even when inspecting a car in person, let along not seeing the bloody thing :)
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
