I don't have the Spool built short motor but I purchased the 3.4 rotating assembly and had my engine builder do the work.
Airflow through the head is hugely important, don't skimp on this. I personally wouldnt put cams bigger than 270 as you don't need the revs especially for street use, make sure you degree them with a dial indicator. With my 26 head and 1mm OS valves, 10.8mm lift and 260 degree procams, mine makes peak power just before 8000rpm with a broad torque curve from 3000rpm. Turbo is a 6466 with twin-scroll 1.0AR hot side. Has made over 800rwhp on 28psi but its useless at this power, I actually prefer gate pressure which is 14psi creeping to 19psi and about ~550rwhp
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7560885
Cootamundra??? Do you mean Temora???
and your talking hp in the thread but quoting kw in your sig, just wondering is all. 550 rwhp isn't anything too unusual - would have thought that you would get more with no real effort, thus my question re kw vs hp - but the torque would be phenonemal.
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561584
No I mean Cootamundra. Motive DVD Drag Battle.
KW/HP.. They're one and the same, sometimes ill quote one or the other haha. Ive made the peak power number that im comfortable running, and the car is useless like this. I prefer the car with around 400-420rwkw (540-560rwhp) as its the least 'scary' to drive and is still plenty enough to bake 3rd gear at 100kmh. Remember we're talking peak numbers here. The car still has 300rwkw at 4000rpm regardless of my peak power so yea its 'torquey'
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561686
Have now found a Neo head locally so have put an order in for a pair of Tomei 143023 B cams
Strangely finding a matching RB25 Neo or later R34 cas unit seems harder to find then the head was ?
Still need to find one or start looking at other ways of timing ?
Haven't looked into much else yet and tbh I didn't think about getting the head ported but its not to say I won't
What power will a std Neo head run to anyway?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562024
760 at the wheels? So over 800 at the crank as a standard head/ports and valve sizes?
Yep I would personally be going to a crank trigger setup. There is a group buy on here at the moment for only $350 or so + machining of the harmonic balancer.
Cheers I will have a look for the thread. Am using a link g4 and have a aftermarket crank damper so I assume it will be compatible ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562421
Cheers, what are you guys using coil wise with the Neo head ? Matching Neo coils or adapted Gtst coils?
Car is using S1 Gtst electrics so still runs a separate amp
Only I've have a set of as new Nissan OE Gtst coils and although haven't tried it looks like their mounts are all out ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562458
You can adapt and make any coil work, with or without separate ignitors
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562967
Sounds good
You got a dyno graph to look at?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7566482
  • 6 months later...
wow, I think that mota & car build might be a bit more involved than mine lol
Have gone for the motor only on mine as tbh once this is built I plan to leave it be
Famous last words ...
As it is I've got my mota built up and in the car, but am now waiting on getting the exhaust manifold modded
Hopefully I will get sorted soon
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7674345
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
