I don't have the Spool built short motor but I purchased the 3.4 rotating assembly and had my engine builder do the work.
Airflow through the head is hugely important, don't skimp on this. I personally wouldnt put cams bigger than 270 as you don't need the revs especially for street use, make sure you degree them with a dial indicator. With my 26 head and 1mm OS valves, 10.8mm lift and 260 degree procams, mine makes peak power just before 8000rpm with a broad torque curve from 3000rpm. Turbo is a 6466 with twin-scroll 1.0AR hot side. Has made over 800rwhp on 28psi but its useless at this power, I actually prefer gate pressure which is 14psi creeping to 19psi and about ~550rwhp
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7560885
Cootamundra??? Do you mean Temora???
and your talking hp in the thread but quoting kw in your sig, just wondering is all. 550 rwhp isn't anything too unusual - would have thought that you would get more with no real effort, thus my question re kw vs hp - but the torque would be phenonemal.
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561584
No I mean Cootamundra. Motive DVD Drag Battle.
KW/HP.. They're one and the same, sometimes ill quote one or the other haha. Ive made the peak power number that im comfortable running, and the car is useless like this. I prefer the car with around 400-420rwkw (540-560rwhp) as its the least 'scary' to drive and is still plenty enough to bake 3rd gear at 100kmh. Remember we're talking peak numbers here. The car still has 300rwkw at 4000rpm regardless of my peak power so yea its 'torquey'
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561686
Have now found a Neo head locally so have put an order in for a pair of Tomei 143023 B cams
Strangely finding a matching RB25 Neo or later R34 cas unit seems harder to find then the head was ?
Still need to find one or start looking at other ways of timing ?
Haven't looked into much else yet and tbh I didn't think about getting the head ported but its not to say I won't
What power will a std Neo head run to anyway?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562024
760 at the wheels? So over 800 at the crank as a standard head/ports and valve sizes?
Yep I would personally be going to a crank trigger setup. There is a group buy on here at the moment for only $350 or so + machining of the harmonic balancer.
Cheers I will have a look for the thread. Am using a link g4 and have a aftermarket crank damper so I assume it will be compatible ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562421
Cheers, what are you guys using coil wise with the Neo head ? Matching Neo coils or adapted Gtst coils?
Car is using S1 Gtst electrics so still runs a separate amp
Only I've have a set of as new Nissan OE Gtst coils and although haven't tried it looks like their mounts are all out ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562458
You can adapt and make any coil work, with or without separate ignitors
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562967
Sounds good
You got a dyno graph to look at?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7566482
  • 6 months later...
wow, I think that mota & car build might be a bit more involved than mine lol
Have gone for the motor only on mine as tbh once this is built I plan to leave it be
Famous last words ...
As it is I've got my mota built up and in the car, but am now waiting on getting the exhaust manifold modded
Hopefully I will get sorted soon
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7674345
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
    • If you are getting that sort of fuel usage, you might as well be back in the stagea
    • Looks good mate, those stainless lines must be a bastard to do neatly. Better get it to a track again sometime soon, I'm doing to Wakie day next Wednesday to see if the v37 likes cool weather better than hot weather....
    • If you've got spark, and you've got fuel, it needs once last thing to go vroom... Have you compression checked the motor?
