I don't have the Spool built short motor but I purchased the 3.4 rotating assembly and had my engine builder do the work.
Airflow through the head is hugely important, don't skimp on this. I personally wouldnt put cams bigger than 270 as you don't need the revs especially for street use, make sure you degree them with a dial indicator. With my 26 head and 1mm OS valves, 10.8mm lift and 260 degree procams, mine makes peak power just before 8000rpm with a broad torque curve from 3000rpm. Turbo is a 6466 with twin-scroll 1.0AR hot side. Has made over 800rwhp on 28psi but its useless at this power, I actually prefer gate pressure which is 14psi creeping to 19psi and about ~550rwhp
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7560885
Cootamundra??? Do you mean Temora???
and your talking hp in the thread but quoting kw in your sig, just wondering is all. 550 rwhp isn't anything too unusual - would have thought that you would get more with no real effort, thus my question re kw vs hp - but the torque would be phenonemal.
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561584
No I mean Cootamundra. Motive DVD Drag Battle.
KW/HP.. They're one and the same, sometimes ill quote one or the other haha. Ive made the peak power number that im comfortable running, and the car is useless like this. I prefer the car with around 400-420rwkw (540-560rwhp) as its the least 'scary' to drive and is still plenty enough to bake 3rd gear at 100kmh. Remember we're talking peak numbers here. The car still has 300rwkw at 4000rpm regardless of my peak power so yea its 'torquey'
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7561686
Have now found a Neo head locally so have put an order in for a pair of Tomei 143023 B cams
Strangely finding a matching RB25 Neo or later R34 cas unit seems harder to find then the head was ?
Still need to find one or start looking at other ways of timing ?
Haven't looked into much else yet and tbh I didn't think about getting the head ported but its not to say I won't
What power will a std Neo head run to anyway?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562024
760 at the wheels? So over 800 at the crank as a standard head/ports and valve sizes?
Yep I would personally be going to a crank trigger setup. There is a group buy on here at the moment for only $350 or so + machining of the harmonic balancer.
Cheers I will have a look for the thread. Am using a link g4 and have a aftermarket crank damper so I assume it will be compatible ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562421
Cheers, what are you guys using coil wise with the Neo head ? Matching Neo coils or adapted Gtst coils?
Car is using S1 Gtst electrics so still runs a separate amp
Only I've have a set of as new Nissan OE Gtst coils and although haven't tried it looks like their mounts are all out ?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562458
You can adapt and make any coil work, with or without separate ignitors
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7562967
Sounds good
You got a dyno graph to look at?
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7566482
  • 6 months later...
wow, I think that mota & car build might be a bit more involved than mine lol
Have gone for the motor only on mine as tbh once this is built I plan to leave it be
Famous last words ...
As it is I've got my mota built up and in the car, but am now waiting on getting the exhaust manifold modded
Hopefully I will get sorted soon
https://www.sau.com.au/forums/topic/457460-spool-34/page/2/#findComment-7674345
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
