Read somewhere that camshafts have/had colors painted on them by manufactures to help identify model and/or brand. Can anyone confirm this? I remember yellow and purple. It was years ago reading a thread and typing camshaft colors brings up more than just a few pages of searches.
Back story;
Helping a buddy with his RB25 S1 and he said that the guy he recently bought it from installed Poncams but had no receipt. He doesn't have any extra gaskets to open up the valve cover so I shoved my snake camera thru the oil cap fill hole. Motor is clean with hardly any deposits so (A) he used a motor wash additive like Seafoam or (B) it was actually installed and head was cleaned. Right after the I2 cam retainer, there's yellow paint between lobe cylinder one and two. Maybe it's because all the RB's I've torn down have more miles on them than what they should so the paint disappears, but I can't say I've ever seen paint on cams before. Poncams or something different? If really needed, the guy will order valve cover gaskets but it sounds like that's $100 he doesn't want to spend and 2 weeks of waiting. Knowing what's in your motor is kinda a big deal if you want to tune it right. [emoji57]
Also I can't say I recognize this cam gear either. eBay special?
https://www.sau.com.au/forums/topic/457966-camshaft-colors/
I haven't seen those markings but a quick search found these guys over your way somewhere, they have yellow and blue or yellow and green markings on their cams by the looks of things:
http://jimwolftechnology.com/customer_part_detail.asp?PartID=461
Another pic here:
http://jimwolftechnology.com/wolfpdf/CAM%20INSTALL%20INST%20FOR%20KA24DE.PDF
Also that cam gear:
http://www.aliexpress.com/item/high-quality-cam-gear-cam-pulley-for-nissan-RB25-RB26/538551458.html
And yeah, as Ben said, just take the cam cover off and have a look, those rubber gaskets are reusable.
  • Like 1
https://www.sau.com.au/forums/topic/457966-camshaft-colors/#findComment-7562154
Another pic here:
Also that cam gear:
Thanks a bunch buddy! If they are Jim Wolf's, that's killer! So the cam gear decent? I've never used a Chinese one. I've always stuck to when it comes to Japanese Tech, use Japanese parts. American tech, American parts. Ben said it'll be fine if you use locktite on the set screws and they'll be fine. Would hate to tell the guy one thing and it doesn't work.
https://www.sau.com.au/forums/topic/457966-camshaft-colors/#findComment-7562197
As said just take the cam covers off. The gaskets are certainly reusable. Don't need to drop a huge amount of cash on name brand cam gears, anything that looks half decent will be fine just loctite all the bolts.
As for cam colours. Just stop. Take the covers off and look at the markings on the cams, they will either tell you what they are or at least have a part number/manufacturer on them and you can find out exactly what they are.
https://www.sau.com.au/forums/topic/457966-camshaft-colors/#findComment-7562275
Guy came by this morning and found this once pulled off cam cover. Also it's what I feared. No gasket. Someone used gasket maker and tons of it. Bump motor to see 360 of cam. No other visual markings but the paint strip, a "T", and cast imprint of "U3" which is the stock imprint. Looking closer at them, kinda looks like a regrind of some sorts. Told the guy if he wants me to figure specs and mic it out, I'll have to charge him. Didn't see any notching in the heads or cover so this shouldn't be 9.5+mm of lift. Jim Wolf Tech has no current RB25DET cams for sell in their catalogs but doesn't mean they never sold them. Those paint markings are extremely similar to what they advertise for other applications. Sent an email and hope to hear back soon. If someone has seen this type of markings before, I'd appreciate your input. Thanks
https://www.sau.com.au/forums/topic/457966-camshaft-colors/#findComment-7562491
Of course it's pretty hard to tell from those photos, but the lobe looks stock to me.
If you image search poncams, or anything else, you will see how much "fatter" the nose of the cam looks.
That sucks about the gasket! People do weird shit
https://www.sau.com.au/forums/topic/457966-camshaft-colors/#findComment-7562495
As I re-read what I wrote, I realized I'm a dumbass. Already knew that yet I wrote it out. I even have the tooling somewhere in the shop.
Thank you everyone for your input. Once again this community is awesome
https://www.sau.com.au/forums/topic/457966-camshaft-colors/#findComment-7565594
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
