Up for sale is my ATI 1000hp balancer.
Condition is pretty much brand new as it was fitted to the engine once but was then removed as I'm going to a crank trigger set up. The engine has never been started.
Comes with everything that's with a brand new balancer inc water pump pulley, stickers and instructions.
Chasing 650 which is reasonable considering the price of Aus retailers and the cost of importing from the USA with the dollar the way it is.
Located Sydney and will post
0432528844
Cheers
https://www.sau.com.au/forums/topic/457983-fs-r3334-rb26-1000hp-ati-balancer/
Forgot to mention that the balancer comes with provisions for a dry sump mandrel
Do have pics on request
More info
ATI Super Damper Harmonic Crank Pulley for R33 and R34 RB26DETT. This truely balanced crank pulley was made to eliminate torsional crankshaft vibrations caused by abnormal wear. It is a direct replacement for the OEM crank pulley. Made to exceed SFI 18.1 Specs with laser engraved timing marks. The ATI Super Damper is also coated with black zinc chromate to prevent rust and reduce wear.
The Super Damper does not retain stock belt size. You will need to measure for the correct belt size.
Damper includes new aluminum water pump pulley for clearance. A/C belt is a 25% overdrive - DO NOT USE BELT IF RACING! 15% underdrive on power steering, OEM size on water pump.
Approximate weight of the pulley itself is about 11 lbs, good for 600-1000HP.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
