I've been buying heaps from Nissan & NISMO direct in Japan lately for my build. Just seeing if anyone would be interested in a Nissan OEM & NISMO group buy? I've got a long list for myself and have managed to be able to deal direct with Nissan Japan and NISMO. All items are genuine.
Prices are best for decent items such as clusters, console trims, mechanical parts, etc.
THIS IS EOI ONLY. MAY OR MAY NOT GO AHEAD SUBJECT TO INTERESTS, EXCHANGE RATES & FREIGHT. NO LARGE BULKY ITEMS SUCH AS PANELS AND BUMPERS.
For this to start, I require at least 10 people to commit. Please post in the following format:
Car:
Part Description:
P/N: NISSAN/NISMO
QTY:
Example:
Car: SKYLINE R34 GT-R V-SPEC II NUR
Part Description: MFD COVER
P/N: Nissan 68411-AA400
QTY: 1
For multiple Items:
P/N:
1 X Nissan 68411-AA400
1 X NISMO 00000-A0000
  • Like 1
https://www.sau.com.au/forums/topic/458070-eoi-nissan-oem-nismo-group-buy/
this might be difficult, but is there a list of major items?
Not exactly sure what people are after and I don't want to spam the Nissan/NISMO staff and make them think I'm only hunting for prices but not buying. But for the sake of ideas, RRP is based of average of Australian Nissan dealers:
R34 GT-T M/T NISMO Cluster - $590 (RRP $800)
RB25 Engine Fans - $130 (RRP $160)
RB25DET Speedo Sensors - $90 (RRP $160)
R32 Speedo cables - $95 (RRP $190)
This GB will be good for mechanical, interior & body parts. Things like seals, gaskets, grommets or hoses won't save much, but should be able to get.
So compared to amayama what's the difference?
I've tried to place orders on items with them before and half the parts came back with NO ETA. Whereas going directly, I was able to source items that Amayama returned with NO ETA. This EOI is just there as an alternative option to Amayama.
Part Description: 2 bar precision boost sensor
P/N: Nissan 25085-RNR45
QTY: 1
Interested, see what price we can get. Thanks Ricky.
I be in for one of these too mate mine only works intermittently
  • Like 1
You'll find Amayama have a No ETA simply because until someone actually hands over the money they won't go and order it.
Makes logical sense for a part that isn't stocked by them. This just sounds ordering a few items for less than Aus (which you can do from basically any O/S supplier).
And you haven't followed the rules here either as you've provided no ETA, no shipping costs, taxes/duties and all the other stuff that all alter the end/delivered price.
Update the thread as per the GB section rules. They are there for specific reasons, reasons which ensure people actually know what's going on.
  • 3 weeks later...
Withdrawn from the EOI please
Car: SKYLINE R34 GT-T
Part Description: LSD centre
P/N: Nismo 38420-RSS15-B5
Qty: 1
Thanks for the opportunity.
  • 1 month later...
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
