Ok i figured ill have to start a new thread on this topic.
I just ripped apart a r32 gtr transfercase. It seems very to simple to pull apart. I noticed a pump in the front that sends fluid in the middle of the shaft to keep the friction disk lubricated all the time that was smart on nissans part. Next i noticed that it has a floating shaft that is responsible for sending the torque to the front wheels via a chain when the friction disks are engaged. Next thing i noticed that there is a spring thats always keeping the for the fron torque disengaged. Next there is a piston kind of like a brake caliper piston that pushed against the spring thats keeping the friction disks from engaging. So as oil pressure increase it starts to work against the spring ans slowly starts to engage the friction disks that applies torque to the floating shaft, chain starts to spin and front wheels starts to spin.
I hope i got that right. ???:unsure:
Here is what i noticed in the friction disk area there is metal plates all of different sizes. Im guessing that you would use one of the small ones to add to a worn unit. How would you measure it up. If its to thick the big clip wouldn't fit on the drum is what im thinking. Next does anyone know hiw to identify a worn friction disk, as i dont have a new one to compare it against.
Ive read online that these friction disks are not avaliable anymore. Is this true.
I really would like to find or create a thread on this build. Please note that this T-case is rusted away and it was only for practice taking it apart.
There was a thread a couple of years ago: http://www.sau.com.au/forums/topic/436604-transfer-case-rebuild/?hl=%20transfer%20%20case%20%20rebuild
and this is the business end:
Transfer case rebuild
Its not the adding of plates.
Its the arrangement of them
There are 19 plates in the standard setup, 12 outers and 7 inners to make up the clutch pack,
Outer = O, Inner = I when reading the layout below.....
Stock is IOOIOOIOOIOOIOOIOOI
Full max grip rearrangement would be IOIOIOIOIOIOIOIOIOI
You only need another old transfer case to rip the plates out of to rearrange your old setup, scavanging the extra inner plates to use, you need to select ones of the right thickness to end up with the correct end clutch pack thickness so some mix and matching is required.
You don't need to go full grip, you can make up your own arrangement of plates like something in the middle like IOIOOIOOIOOIOOIOIOI
Same theory as playing with a Cusco LSD clutch pack arrangement, see page 9 below.......
http://www.cusco.co....Guide Final.pdf
  • Like 1
Just to clarify this is not my work ... I was just quoting Peter (GTRPSI) but I assume same as you. You could confirm by counting the plates in a newly opened box - if there are 7 friction plates then yes they are the I plates and the other 12 are the O plates. PS please confirm when you have done this count!
Hmm. Thats is right. But i have 13 O plates. Looks like someone has shimmed this old transfer case already. I noticed the end plates are way thicker (O) plates which makes sense.
I would like to replace the friction plates but i cant seem to find them for sale. Only place i know is NO1 set from IIRC is RKTuning. When i go to there website i can seem to get there email.
Edited by MJTru
Ok i understand whats going on. There are 2 outer big rings called the retainer plates then the 12 driven plates and 7 drive plates. Thats all original. The end measurement has to be .2 to .5mm by the retainer clip. Thats wit all the disks in the drum.
That's interesting, it's only one plate that you need to change to adjust the preload, which would mean all the inner and outer plates are the same thickness
As for where to order email rhd
  • Like 1
I have contacted them and awaiting a reply.
If i only have to change one plate that means the wear is very minimal.? Once i burn out this clutch i have i will pull it off the box im using at the moment. I was looking at how the design is. As it wears the piston on the back of the gear box would have to move further outwards to engage the disks. I was thinking if there was some kind of adjustment that could have been done to take up for the worn disk. Like in between the piston and engagement leaver.
Just a thought here.
Edited by MJTru
Thats right, 7 drive and 12 driven plates.
Remove driven and change to drive so you have a drive driven drive driven combo.
Use the link back to cusco diffs in the other thread to understand how to increase lockup. :)
worn discs look a little like this.....
Don't forget when measuring preload you need to have the shaft/hub setup installed case with the hydraulic ram/fork etc installed too. Preload is adjusted (Nissan manual) by changing the thicker end plates as you've noticed- you can buy the discs with the correct thickness from Nissan, incremented sizes like shimming. (you can also buy new friction/drive discs from Nissan. At Nissan prices) Or get inventive with machining- adjustable push-rod length between fork and piston would be my choice of mod too......
Wow those arnt worn there missing the actual friction material. Lol
I did notice that they sell the plates with different thickness in the manual. Rhd took long to reply, but they asked for part number. So ill have to do my measurements before hand. What nice to know is that now i know all im changing is the thick plates. (Shimming it) i was thinking i would need to add a small disk. Talk about wrong. Please look at this link. I cant seem to find the email address and does anyone know if they still make these. ???
http://www.gtr.co.uk/forum/165575-group-buy-n01-transfer-box-race-clutch-pack.html#/forumsite/21025/topics/165575?page=1
Edited by MJTru
According to Google:
www.rktuning.com/html/contact.html
Address: Unit 4 Nashlea Farm Poors Lane North Daws Heath Benfleet Essex SS7 2XF Telephone / Fax: 01702 557124. Business hours: 8:30am to 5:30pm
email address: [email protected]
I have sent them an email. Well after launching the car i can really say its no where close to how my r33 gtr gets off the line. Somthing is definitely wrong with the transfer case. Its doing something but not pulling as it should. Im going to pull it down and see whats up. I upgraded the clutch and drained the transfercase oil and noticed it was bark in color. Keeping in mind this oil has no more than 2000km on it. It shouldnt be that dirty. To add the electronics are working fine. It goes to full 50/50 split the mechanics just aren't doing its job. Has anyone used the kit from Rktuning before???
Edited by MJTru
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
