Hi all,
I have decided to part with my road set of rims for my GTR. These are the four Volk Racing Winning 'Y' spoke rims that I bought my GTR with, in 18 x 9.0 size. They are a +22 offset to suit a GTR although I believe that they may fit a GtsT. Two rims are in excellent condition with only minor marks but the other two have some gutter rash and other marks on them (please refer to the photos for condition). All rims have their original labels and decals and I am including the Rays centre caps as shown in the photos.
These are located in South East Melbourne, Victoria and I would prefer pick up.
$900 ono
Please message me back through SAU and I will provide a mobile number to those who are interested.
post-6243-0-66180000-1437358156_thumb.jpg [sharedmedia=cor e:attachments:490368] post-6243-0-13053700-1437358302_thumb.jpg
post-6243-0-14182200-1437358335_thumb.jpg post-6243-0-61695700-1437358353_thumb.jpg post-6243-0-15198200-1437358410_thumb.jpg
post-6243-0-84370900-1437358385_thumb.jpg post-6243-0-18902700-1437358437_thumb.jpg post-6243-0-55229600-1437358444_thumb.jpg
post-6243-0-58109100-1437358448_thumb.jpg post-6243-0-68676900-1437358452_thumb.jpg
No interest in these cheap, great looking Rays/Volk rims?
I should have added that these have never been repaired or bent.
If you are unsure how they will fit/look on your GtsT, I would be happy to arrange a trial fitment.
Thanks for the comment Chris...I take it you have a set of rims with this offset on your gtst?
Yep, I run 18x9+20 245/40s all around. Just rolled guards so they fit :) Edited by dontyellpl0x
Hi bro, just wondering what's the tyres like or is it for rims only? As these would look mint on my 34gtt.. Hopefully talk soon. Cheers
G'day mate...tyres still have plenty of tread but there is a bit of wear on the inside edges. However I should add that the tyres are pretty old and the rubber itself is probably past its best.
Hi bro, yeah I'm very interested in these wheels what would be your best price for a quick SALE as I am trying to sell a near New set of Konig wheels but if low enough I will get before hand. Cheers mate and hope to talk soon. Mick
Hi bro, can you please pm me your number so I can give you a call as I will buy them we just have to work out a price? Cheers mate talk soon. Mick
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
