I recall, (i think it was fatz) suggesting a few couriers to get some wheels from Sydney to melbourne.
Doesnt have to be overnight courier or anything, but cheap would be good.
Anyone have any suggestions.... for a lazy $100 im a chance of getting someone i know to backload it on a trip back to Melb, but id rather spend the money and get the rims now, not when he can do it.
https://www.sau.com.au/forums/topic/45874-interstate-couriers/
Having sent rims interstate before I used Scotts Transport at Revesby. From memory it was $40 for a half pallet. Only catch is you have to drop off and pick up the rims from their depot. But if cheap is your aim it can't be done any cheaper than that.
Richard
Ok, found the details anyway. Their melbourne contact details are:
19-21, Link Road, Brooklyn, ph: (03) 9314 4877
and in Sydney:
Scott's Transport 202 - 214 Milperra Road Revesby, NSW ph. (02) 9773 3355
Richard
Your rims are ugly anyway, you don't want them...
But at least they're nicer than Chris's ones :spew:
I prefer to be called ugly then WRXBOY... :Oops: Note to self : Gold was a bad move :throwup:
... i want to be like Steve, got one of his turbos, half the driven wheels he has, and now got lookalike wheels :cheers:
..and thanks mmmGTIR
p.s. Scott's transport told me they don't do small or personal items.
The bar stewards. They've done it for me a few times now. Wheels (a couple of times) and a cat back exhaust once too.
hmmm. I *may* have given them the impression that it was a business thing though. But I sure didn't supply any ABN or anything and I paid in cash.
Richard
I posted a set to melb not long ago, about $70 from memory....just get big box :D
The Post Office generally wont accept anything over a certain girth. Can't think of it off the top of my head but it's listed on their site.
Richard
I just had to pick up an exhaust system from the post office, a "trainee" accepted it for delivery then the postmaster there had a hissy fit and handed it back. At first they said anything with a dimension larger than 150cm is too big, then he said 100cm....
Need to find a courier asap... if all else fails I'll TNT the sucker.
Still doesn't change the fact that your rims are horrid. Ever wonder why no-one out here has them?
Whose rims...mine, your kidding right, they rule... i like to experiment with colours :P
Scotts wont touch them, but just founf a place called Vic Valley couriers that will do it for $60, an acquanitance (i have no friends because my wheels im told are lame:Oops: ) has used them without probs.
Since they are so ugly you are probably right to wheel them out and leave them on the curb unitlt hey get picked up, they wont get stolen, but their ghastly appearance might drop real estate prices in your streer :Oops:
Yeah, Andrew's rims are the shockers. I can't comment on yours Troy cause Steve's got them too... although now they are the RVR rims. Go the Spastic Van!
Might look different on the car though, have to wait and see. If I'm bored I'll put them on my car :P
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
