Hi guys,
I have an issue with my R33 and I am looking to see if anyone else has had the same problem.
I am taking the car over to my tuner (DVS-JEZ) in two weeks to further diagnose the issue, but I figure it can't hurt to ask on here as well.
Car:
1996 ECR33
Stock motor
Nistune
GT3076 .82- 45mm external gate on housing, stock manifold
ID1000 injectors
Bosch 040 in-tank pump
98 pump fuel
Turbosmart FPR
Z32 AFM
Splitfire coils
Blitz return-flow cooler
3" straight through exhaust no cat,
E-Boobs street
I ran the car at NSW Time Attack in June and the car developed the following pain in the arse:
- Car ran beautifully for almost 10 laps
- Then it started to lose horsepower.
- At WOT the turbo would make close to target boost but would not accelerating as it would normally (almost felt like I had reefed the handbrake on)
- It I kept driving, within one lap it would start to misfire, backfire and carry on badly on boost (and with pretty much any load)
- Brought back into the pits, refuelled and went back out- same misfire condition immediately.
- Allowed it to cool down for an hour or so, the misfire condition would appear after 2-3 laps.
- Allowed it to cool overnight and did another session first thing in the morning- Same deal after almost 10 laps.
It seems to me in my uneducated mind that it is heat related... but what exactly, I have no idea.
My first suspect was fuel pump as it has become very noisy recently (particularly when hot)
I have checked intercooler piping for leaks/tears and none detected
Have not been able to check fuel pressure when driving
Any thoughts or similar experiences would be greatly appreciated.
Happy Monday folks!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
