Ive just got a 25det neo running in my stagea, but theres a knocking coming from the intake cam when the vct solenoid isn't open. When its idling up until about 1400rpm you can hear the knocking but when the vct opens, above 1400rpm, the knocking goes away and sounds mint, ive tried replacing the solenoid with another one but to no avail anyone had this before?
https://www.sau.com.au/forums/topic/458930-rb25det-neo-vct-knocking/
So i changed the cam gear with one of a 25de neo, and i noticed that the cam gear was bolted up differently to the original one, the de one was bolted central to the vct and the det was bolted hard one way. I ran it how it was set and was lacking alot of top end and didnt keep pulling at all after 5000rpm, so i moved it the same way hard as the original one and still is lacking top end and it feels like its surging when you put your foot on it? Is it too advanced? Could the cas need adjusting? post-140767-14402025659652_thumb.jpg
not sure if related, but when I did my timing kit and removed the VCT solenoid to take the seals off, I over tightened the VCT using a rattle gun (being lazy of course). Some how I jammed the unit and the car was sluggish down below...
Make sure it's sitting in the right position before torquing it up to spec.
Man, I meant the whole vct unit along with cam gear.
I thought it was kind of obvious.
Changing just the actual gear part is a bit pointless, it's the actual vct actuator part of the car gear assembly that needs to be changed.
I changed the whole unit, not just the outside gear, the knocking has stopped, reading up it sounds like timing, a mechanic mate is bringing his scanner over later and will plug it in, to make sure the timings right
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
