nah they arent well i dont think they are.
You be the judge.
just wanting to know best way to go about turboing this car. like sort of turbo etc, ive got a fair idea on what i need:
exhaust manifold
turbo
oil feed and return line
ecu
intercooler and piping
fuel pressure reg
and so on, just need an opinion of someone who has been around nissan motors
Start saving for pulsar gtir. They're worth f**k all these days anyway
There's a reason most are cheap.
You got pulsar questions?
PGA is dead, but there's a lot of people on the Facebook page.
Otherwise SR20-forum.com is the place to go. N14-15 is similar to B14 sentra.
Also I've rambled on about basic pulsar mods on ozpulsar.com.au
yeah I was gong to suggest a GTI-R too, they have the best version of the SR20, big factory intercooler, proper awd driveline, etc
finding a good one will be the painful part, most have been trashed to death. barely see them anymore
Sorry but that's incorrect. Everyone goes VE for a reason.
I'm doing my last 54C (gtir) build now. Never again. Parts getting too hard to find with little benefits.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
