Hi all,
I hope all is well.
Can someone please help me understand what boost pressure sensor does and how it works with the ecu?
I was under impression that it is used by the internal gauge sensor but don't think that is the case and believe it feeds back to the ecu so engine will run lean or rich
Also when unplugged engine light comes on
I am asking because the head of mine broke and I glue it back together but it keeps breaking . When unplugged engine light is on and when not unplugged car is extremely lean if no line is going to the sensor on idle( reading my narrow band o2 sensor )
They are £40 on eBay for second hand which seems a lot
brand new is £150 from dealer. what a rip off
Do you know anywhere that sells brand new ones ?
Part number is Bosch ps66-01 hitachi 8529
My car as you might know is rb25 r34 get.
Picture is
http://i8.ebayimg.com/06/i/000/af/eb...5.JPG?set_id=7
Edited by stranger12
https://www.sau.com.au/forums/topic/459058-boost-pressure-sensor/
There is no MAP sensor on R34s. Well, at least there is no (M)anifold (A)bsolute (P)ressure sensor that is used by the ECU as a primary load sensor.
There is a MAP sensor to drive the boost gauge on the dash. This is not connected to the ECU.
There is a boost sensor, which is not really any different to a MAP sensor, except that it is not connected to the inlet manifold, therefore cannot be called a MAP sensor. This sensor is known as the boost sensor and is connected to the crossover pipe. The ECU does use it for making some fuelling decisions and for overboost protection, and you are correct, it will chuck codes if it is unplugged.
well on mine no codes at all. but the engine is not running fine .
I had a look at this post (below) and the guys says it is map and swap it with Haltech 3-bar MAP . I don't want to pay £150 if I can replace it with a haltch sensor but some are saying it is boost sensor and some saying it is map.
I don't get any code but just engine light.
http://www.sau.com.au/forums/topic/389661-link-g4-plug-in-vs-vipec-v44-plug-in/page-5
yep mine is a standard ecu. so 100% that is a boost pressure sensor not map sensor ?
I have seen number of posts people saying they have unplugged them but certainly it does impact the running of the engine so how can you unplug it and get away with it ?
Pretty sure they are only used as overboost protection.
Scotty, I was 100% with you until recently. But I have had a few people tell me strenuously that it is also referenced for some transitional fuelling decisions. I haven't actually looked into it myself or checked with Matt. Might have to have a little dig around the Nistune forums.
I just disconnect the hose on the Stagea's I tune, but you are correct, once tuned it would make no difference as the fuel map is modified. On a stock car it may well be used for minor corrections, either way you need it there and plugged in on the Stagea to stop the code.
All this because the OP is too tight to buy a new sensor... Just get one from a wrecked M35 if you want one that's not brittle.
Not tight but too mich for little plastic sensor that cost 30 pound brand new for all other cars and 150 for mine !
What is m35?
I am happy to pay the premium of 150 but rather buy an upgrade or somethibg that is worth the money and not the same sensor just for me to take it out few month down the line when i upgrade
When you unplug the pipe and have the sensor plugged it, it makes the car run lean. On idle my o2 reading is 0.5ish and with the sensor plugged and pipe blocked it is reading 0.2 and sensor unplugged and blocked around 0.8
FFS buy another sensor. Are you in England? Maybe not too many used ones around - try what I said yonks ago and email Kudos Motorsports - it won't cost you anything to find out if they can supply.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
