Hey guys, I've tried googling to no avail so I thought I'd post on here.
My r34 gtt oil temp seems to get getting kinda high lately and I've no idea what could cause it. It sits around 100 degrees and today it got to 110. All the while the water temp is sitting just below half way.
When I bought the car, I got a radiator shop to flush out the stock radiator and install a new top tank. I've just put a new thermostat (genuine Nissan). The only thing I could think of that would be causing the oil temp to get this high was my sump having a large dent in it. I've since installed a new sumo and the same thing is happening.
All the google results in sau and other forums either talk about water temps or seem to be saying to get a new radiator but I've just had mine cleaned and repaired so idk if it's worth doing still.
I'm running penlight full synthetic 10-50 from memory (it was just whatever repco recommended for the car, might not be 10-50) with a k&n oil filter
Halo please
https://www.sau.com.au/forums/topic/459248-r34-gtt-oil-temp-problems/
What oil temp sensor and gauge are you using?
Have you considered shooting the side of the sump with an infrared pyrometer when the gauge is saying 100 and see if the sump is close to that or a long way away?
Have you fiddled with any oil cooler/filter relocation plumbing lately? (See other recent thread in this very forum!!!)
Sorry, forgot to mention. It's the stock triple gauges and the engine is completely stock minus a bov. Haven't done anything to it other than fixing the sump, radiator and thermo. Whenever I start the car there's a belt squealing, would that maybe be the clutch fan?
Not sure why people dis the factory gauges so much, most of the time it either works or doesn't
Only bad thing about it is the lack of detailed scale
Sensors are shared with the GTR MFD sensors anyway, haven't heard anyone saying that the MFD is inaccurate
Could even be a bad connection or earth causing the faulty readings.
Grab radiator hose, feel the heat, grab oil filter, it shouldn't be double the temp.....(backyarders way and it should be pretty obvious)
Just putting it out there, 100 degrees after 30 minutes driving is not high. That is a very realistic and normal value for that period of driving plus other external conditions. If you start exceeding that drastically say like 120-30 degrees regularly then you start to have problems. But the oil temperature remaining around 100 degrees is fairly normal after long periods of driving. The scaling is also very bad so you could be over estimating its actual value.
Secondly your water temperature will not be half way. I am assuming you are using the standard C to H gauge as the indicator which has no number scale on there so you won't be able to know what the actual value is. It would probably be around 80-85 degrees ideally for stock radiator and that is an acceptable value.
If you've changed nothing recently like oil cooling or what not as mentioned then the oil temperature sensor could be on its way out.
yeah thats what I'm thinking, the oil temp sensor could be dying. it is an old car after all. anyone know where to buy a replacement? or any way to test the current one.
its doesnt seem like the car is running hot, as I said before it still drives fine and no other warnings or temps are going off. a few mechanics said that 100-110 isnt really anything to be worried about and to be honest ive never really paid attention to the gauge till now anyways so i have no idea what it was running at before.
is there any way to test the earth or check them?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
