Hi everyone. Have been talking to a guy at the gym re the Nissan Skyline Mass Air Flow sensor on our cars after we have found that he is getting about 700km's around town whereas i am getting about 520km's around town. Same vehicle (2008 350GT S), roughly same area times of driving and similar driving styles. i've have noticed that my car is idling quite roughly and he mentioned the Mass Flow Air sensor may be stuffed and this could be causing both the economy difference and the idling problems (as per this listing on TradeMe. http://www.trademe.co.nz/Browse/Listing.aspx?id=937190669)
Wondering if anyone out there can let me know if this could be an issue (have taken the AFM's out and they 'appear' to be ok - my car has just clicked over 50000km's) and worth me replacing them. I can see that there are plenty of other places online overseas selling these a whole lot cheaper than this guy.
Cheers for any advise guys.
https://www.sau.com.au/forums/topic/459279-v36-skyline-mass-air-flow-sensor/
Have you tried cleaning them?
Realistically the o2 sensors should re-tune any discrepancies out of the map anyway. Could just be different driving styles?
There are many aftermarket AFM's out there, but in your case I would be buying genuine if possible. Unlikely both are faulty, if you got it on a Consult3 you would easily see if they are reading the same as each other.
700km around town for a V36 seems a too good for city driving... I reckon there is a good bit of crusing mileage in that...
In my 3.7 on the 10km school run I get about 12.5 l/100km, but on a good 50km freeway run, easily getting 8-9l/100km..
check your actual economy (L/100km), and get him to do the same KM/Tank is a poor indicator of fuel economy.. way too many variables. How low he lets his fuel tank run may well be different to how low you do. I could technically get over 700km out of a tank on my V35 with urban driving, but I would need to run the tank lower than I am comfortable with. I usually get to about 600-650km before filling.
Cheers for the advise/info guys. So pretty much don't just buy new AFM sensors and replace them without getting the car checked (i imagine Cockram Nissan in Christchurch would be the only place to do this) is what i am hearing. I've been using an app to monitor economy the last few fills and its showing about 12.8-12.7ltrs/100km's which concurs exactly what you have said nickcorr.
  • 3 years later...
What for? Measure actual use in litres per 100 km and report what kind of driving you do -short city runs -city and bursts on a motorway - country cruising...
Also check your tyre pressures and if you have a few km on check or replace your plugs.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
