I was planning to change the timing belt over the weekend (first time since I have had this car) and when I got to the harmonic balancer the bolt was loose and the balancer is stuck on.
My concern is that the key way is bent, basically I was putting as much force on the puller as I could with a 1/2 inch ratchet, and wasn't game to try with a breaker bar.
Now I'm wondering whether I just leave it as is until the water pump or timing belt goes and then rebuild or do I sacrifice the balancer and puller to get it off and hope the crank is ok.
Any advice or tips from anyone who has been in this situation would be great
https://www.sau.com.au/forums/topic/459352-rb26-harmonic-balancer-stuck/
Try using some WD40 on it and leave it for a while to penetrate??
Also maybe Freezer spray???
Never had it before, but just thinking of other bolts and pulleys/cogs and how I've got them off and Oxy warming is prob not a goer for this one lol, although I have heard of jugs of boiling water being used.
Yeah I will try lubricating some more - main concern is that the key way is damaged and if I force it off I will be up for a new crank.
I was using a bolt type puller but it looks like someone else has had a go with a claw puller because part of the lip on the front has been snapped off
OP mentioned Bolt was already loose, ill bet key way and key is damaged.
Get the best puller you can and have fun now.
Dont let it go till the belt breaks......valves will meet pistons.....
I hate to be captain pessimist but there is a bloody good chance your oil pump is on it's way out too.
On RB's loose balancer bolt quite often leads to shattered oil pump. Happened to me and a few others I've about.
If the balancer bolt was loose often the balancer will flog out the key way as well as the key.
Then the balancer can rotate slightly and jamb on the remains of the key.
I'd persevere with decent puller bolts.
Easier to do this work in-situ than chasing an engine around the shop on a stand.
  • 3 months later...
i am picturing some king of clamping mechanism locking a router type tool into place on the crank
Yep, but good luck getting it close enough into towards the block with the motor of the router in the way.
Only way is crank out and CNC or manual mill a new one in.....
It can be done by hand, if your just fixing it to sell, but good luck to the poor sucker who gets stuck with it.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
