I know your going in tomorrow and it should be found.
But could you tell me what is the current rate of water loss?
Do you believe it leaks whilst driving, or after you have driven for 20 minutes or more and parked it?
Does it sound like its bubbling when you stop?
Have you had a real good look and feel around the back of the block near the fire wall?
edit: It's been my personal experience when you stop a leak another is found. UNLESS all hoses are replaced.
I hope this was done during the build. Although CRD failed to do this with mine and I had 1 leak then another. So bit the bullet and did the lot.
Edited by Sinista32
It's honestly so hard to keep track of your escapades.
I like how you broke it down in that post just now.
Are you taking it to a local mechanic? Make sure everything is documented for possible future dealings with crd
In general engine builders won't change all the hoses, sure they inspect them and make a recommendation if they are substandard, but unless the customer requests it they won't change them. Edited by XGTRX
I can understand that.
It's not until they start leaking and you start replacing them it becomes clear what a pain it can be and how much easier it would've been to replace while the engine was out. Under the plenum and back of the block especially.
  • Like 1
As I said, the water lose started the first day I drove it home from the build. I do not know what hoses were changed, the one with the leak was on the car before the build.
It would loose about 500mm on a drive using boost over 60klm , it is the SAME as it was after the build, no more, no less ??
I went to Newcastle Saturday, drove around over the 2 days, about 420klm and it used about 700mm all up. No sign of the motor over heating. Nothing to see.
I looked for the leak fro 3 months while I waited for it to go back into the shop. FOUND NOTHING!
It was in the shop for a month before they said they found the problem, They changed the orange hose and it was alright for about a month and then it went slowly back to how it WAS after the build! That is why I asked about stop leak products.
You cannot see where the water goes, how many times do I have to explain this.
What I love about some blokes on this site , I get pissed on because of the shit that has happened to me and I ask for some advice, I DID NOT DO THE WORK, I DID NOT BREAK ANYTHING, I PAID TO HAVE WORK DONE LIKE THE REST OF YOU BLOKES. I DID NOT WANT THIS SHIT TO HAPPEN!!!!!
For you blokes that go on about me having too much money and know nothing about cars, I know what I want and paid to have it done and except for fark ups from the mechanics side my car now runs the way I wanted it to. It has good response and keeps going. :nyaanyaa:
Wish I had enough money to pay someone to do my cars. My knuckles and back are jealous.
Hope they find the leak mate and you can finally enjoy the car without worry.
Thanks mate
Still driving the car as normal, just check the water every morning. But from some of the advice I have from a couple of blokes that actually read the posts before typing, I had better get it sorted ASAP or I could have a major motor melt down :(
I know about backs, I am a retired upholsterer . worked Fn hard to be able to do this build , I never whinged about the money, only when I had bad results that should have been sorted before the car was given back to me ?
The way some of the blokes go on you would think I wanted this shit to happen, got me stuffed if I can work some of them out as they seem to get pleasure out of someone elses problems ?
Thanks mate
It's not that. It's that you enjoyed a lot of the shit talking and piss taking in the last thread, light hearted humor while knowing full well that the problems have to be fixed and the stress and worry should be on the builder and tuner and not yourself. But we can see it's got you and a few members quite worried.
It should have been sorted before it was given back to you, but humans do have moments of lapsed judgment and sometimes moments of complete stupidity, especially when it comes to money and time spent.
All I can say is is that yes the leak must be found ASAP. Could be a number of things or a multitude. Whether that may be hoses, cores, gaskets etc.
Just sit back and let them find it. ;)
I love the piss taking and take it in the way it was intended, just sometimes it is just smart arse talk from little boys and I like to fire a few cheap shots back, haha
not everything is going to go swimmingly with a 15 year old car pumping more than double its original power output.
especially when you are so concerened with "time" and the way a certain workshop has treated you (most probably due to your age)
In short, you cant see where the water is going then the water must be lost internally. and at the rate of loss you are describing it will almost definitely have to go straight back to crd.
The bloke that does my work here has been building and racing cars all of his life but more the V8 types of cars , so he will be able to give it a good going over and I will then take his advice should I need to take it for a head off job as he does not have the equipment for tuning etc should it need it and I would like to do it all at once and I will take it to Jez.
You are serious right? Or is this a joke?
What has my age got to do with a professional workshop doing the work properly the first time, oh and the 2nd time, whoops 3rd time ?
As far a the car being 16 years old, there in nothing much left under the hood that is not new and the drivline is the same.
Doing this sort of build, I think one should expect to have new hoses. But I do not believe the problem was ever the hose , but ??
You may except this situation but for me after you have given someone 3 goes at something it is time to move on.
I was told by the builder that the car is fixed and I should take it to my local bloke as the new lwater lose should not be hard to find, you just gotta luv em :wub:
They have washed their hands of the car and mentioned "the car has had substantial work and tuning performed on it since it left here a few months ago."
So as far as they are concerned, I am on my own, but it will depend what the problem turns out to be ?
Exactly, they know you dont know your way around the car and they stereotype you as a "old man" that wont follow anything up.
You say "everything" should have been done. But in reality that is not how it works, because people have different goals, skill level, visions and blah blah. If you want something specific done then you ask for it. As soon as you drop a car off and say here is my wallet I want xxx KW then you will most definitely be taken for a ride.
Before you fly off the handle, this is not a dig at you so relax.
And seems like it was a nice ride for CRD which my opinion of has changed substantially.
You are kidding, right?
I chose all of the parts to go in the car (except the Turbo) and bought most of them before the build started and had it dropped off at the shop.
I knew exactly what I wanted from the car and GOT IT, might have had to go to someone else to finish it but got it done. My car works fine with the work " I " had them do, how they did it is out of MY control.
I did not hand them my wallet, I got a quote from them. Checked it out through 3 other shops and it was under the other quotes but the final bill was about the same, so what are you talking about???
Stick a good driver in my car and except for the brakes and suspension it would give most a run for their money , track or street.
Best of all, I farken love it :wub: Just need a jug of water and away you go :action-smiley-069:
Edited by Nismo 3.2ish
Simple solution here...........sell it to me!!! Of cause I will be broken hearted about the leak but I've live through it :rofl2:
Seriously, stick at it, its only one small nagging problem.........12 months from now you won't even remember it [well maybe a little bit].
  • Like 1
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
