Hey all
I am interest on how bad are my wheels sitting with camber and toe i have attached an image that i received when the wheel alignment was done.
All i can assume is the target data is the data they believe is the best for my vehicle, it is stating on the on paper the vehicle i drive
thanks
Edited by kresot9
OK. 4 degrees of -ve camber on the rear is just bloody stupid. Is it lowered until the exhaust is scraping on the road? The only time that much neg camber makes sense is on a very fast circuit car on slicks.
Your original rear toe numbers were massively toed out and it would have felt awful. The new settings are still toed out and it will possibly still feel unsettled. That is unless you like a really active rear end. The other possibility is that I am reading your sheet wrongly. I had assumed that the target data for the rear was indicating toe in (which I would expect). If it is fact recommending toe out, then you have a lot of toe in and it will be a bit dead . This is an important point because it impacts what I have to say about the front toe.
Your front camber numbers are about as highly negative as I would want on the street. For a street car I would go for a little less.....like -1.5°. But -2 is OK. You will wear the inside edges of the front tyres a little faster than the rest.
Your front caster numbers are high and OK. That is about where people would like to have them. I note that they did not change them in the alignment.....does this mean you do not have adjustable caster rods on the front? If you put some on you may be able to get even a little more caster if you wanted.
Your front toe was all f**ked up. It probably needed a lot of steering wheel angle to drive straight. Either that, or the steering wheel was pulled off and put back on one spline out!! Your new toe is at least even. It appears as if the recommended toe at the front is toe out. That's not normal - normal Nissan specs are toe in. So I may be reading your sheet backwards. Anyway, if the spec is for toe in, then you have a lot of it and it will be dull. If the spec is for toe out, then you have a lot of toe out and you will find it very darty and possibly hard to control. And if it is in fact toed out, then coupled with your -2° camber, you will almost certainly destroy the inside edges of your tyres.
The normal system for reporting toe angle is that +ve is toed in and -ve is toed out. In that case both ends of your car are set up with quite a lot of toe in, which will be dead and dull to drive. At least at the front they might have done it to compensate for the wear from the front camber.
Is your car heavily modified or accident damaged?
The shop has been unable to reach their target figure in most cases. I am surprised that they couldn't get the toe right as there is normally plenty of adjustment available.
The front castor is fine but the camber is a bit high and will chew out tyres. The rear camber is as GTSBoy says OTT.
You didn't make the same mistake I did and get a cheap alignment done did you? I had one done last year on my R34 sedan and they completely f'ed up all the settings.
What happened was they were looking for the make and model in the alignment machine database, didn't find a match (surprise), and just randomised some other car's settings.
They also had a completely blank look when I started talking about the adjustable arms I have, lucky to have had the skill to turn the alignment machine on I reckon.
My recommendation is to take the car to a reputable shop and pay for a proper alignment.
I think we can safely say that Kres is located somewhere in Eastern Europe. So whether or not the alignment was "cheap", there is going to be a fair chance that the shop is not that familiar with Skylines. Although, I have seen plenty of 4 door R34s in the porn that comes out of Czech Republic, Ukraine and Russia.
Or he has hectic stance and fitment bro and need the camber to make the wheels actually fit the car
It is toed in front and rear which is right and for the amount of camber is pretty close to where you'd want it, the camber ridiculously high but as I said before that could because of hectic fitment
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
