Rear Window Water Squirter Wont Stop Leaking
I purchased some (used but new to me) Yokohama A050 Mediums to try out for the first time and fitted them up to one of my sets of Rays TE Fortesst's. Sizes are 235/45R17 front and 255/40R17 rear. They are very chonky compared to the same sized AD09 on the same sized rim. Some fiddling will be needed to make them fit. How much camber do these like as a general rule? I imagine more than the rear camber of -1.5' I typically run. So my plan is to target -3.8 front and -2 rear
You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
