Had boost leak from stock BOV so fitted a Turbosmart Kompact Plumb back.
Fixed the leak but now have shudder.
This flutters on release and shudders the car quite a bit around 80 km/h and over.
Assuming it's the recirc pressure causing the problem ?
Any way to fix this ?
VQ25DET
cheers
https://www.sau.com.au/forums/topic/460163-bov-causing-shudder/
Hey mate, i dont have a solution, but i did have the same issue, also did it under load up hill at lower speed on gear change.
Another thing i found was with the bov and hi flow i had the engine cut out at max revs in 2nd, watch out for it, ull.head butt the windscreen!
Happy hunting mate, im keen to see if theres a solution!
aahh that was my next question ?
didn't think it was adjustable .
there's no mention of adjustment in the instructions...
aren't they just set to a certain spring rate ?
Edited by conan7772
I have a dual port I would swap you for, I prefer the single, but the dual is adjustable so you can tune out the stuttering.
At least now you know why the stock BOV leaks, it's done from factory to remove that stuttering.
There are two things that can cause this. Too hard a spring (turbosmart can supply a softer Spring) and in some cases (mine one of them) there is a retractor in the bov control vaccine line. I replaced that line and the shudder went away.
so the Nissan Kompact Plumb Back isn't adjustable ?
what about blocking the recirc ?
if you can tune it out with the dual port, it must be the recirc pressure causing it
Edited by conan7772
i changed from Blitz plumb back --> Stock BOV --> Turbosmart Kompact plumb back
Blitz is adjustable with soft spring --> has shudder (pigeon sound)
Stock BOV --> big leak over 17-18 psi
Turbosmart kompact --> has shudder (pigeon sound)
i did some changes below:
1. keep BOV vacuumto plenum (no.1 in screenshot)
2. join stock ECU boost sensor with stock boost gauge sensor together and connect to plenum (keep using stock boost gauge sensor vacuum (no.2 in screenshot)
3. using a long vacuum pipe connect from stock ECU boost sensor vacuum source to intake pipe (share with stock boost controller solenoid) (no.3 in screenshot)
that could slightly reduce the shudder but can't 100% sort it.
A tune can sort it to some extent, but it really needs to remain plumbed back to the intake, or the afm will misread the airflow and dump fuel. You need a MAP ecu to vent atmospherically without affecting the tune.
You can block the bov but you will get sick dose, and probably snap the turbine off it's shaft.
No shudder on mine since the first tune, I have had the Kompact on for 5 years now, very reliable and quiet with the stock airbox.
Jesus Christ, All that extra wiring and lines is hurting my brain! Don't you at least try to hide extra wiring in your engine bay?
Why have you connected the BOV to the wastegate pressure reference line?
The BOV needs a pressure/vac signal on the engine side of the throttle body. Without vacuum; the BOV won't open when the throttle closes.
I put a grub screw in the OEM BOV bypass, no sick dose sounds and no studder, but that could be because my Hypergear SS2 is currently hella laggy. Did pick up a noticeable improvement is response with an extra 2psi at the same boost setpoint.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
