Had boost leak from stock BOV so fitted a Turbosmart Kompact Plumb back.
Fixed the leak but now have shudder.
This flutters on release and shudders the car quite a bit around 80 km/h and over.
Assuming it's the recirc pressure causing the problem ?
Any way to fix this ?
VQ25DET
cheers
https://www.sau.com.au/forums/topic/460163-bov-causing-shudder/
Hey mate, i dont have a solution, but i did have the same issue, also did it under load up hill at lower speed on gear change.
Another thing i found was with the bov and hi flow i had the engine cut out at max revs in 2nd, watch out for it, ull.head butt the windscreen!
Happy hunting mate, im keen to see if theres a solution!
aahh that was my next question ?
didn't think it was adjustable .
there's no mention of adjustment in the instructions...
aren't they just set to a certain spring rate ?
Edited by conan7772
I have a dual port I would swap you for, I prefer the single, but the dual is adjustable so you can tune out the stuttering.
At least now you know why the stock BOV leaks, it's done from factory to remove that stuttering.
There are two things that can cause this. Too hard a spring (turbosmart can supply a softer Spring) and in some cases (mine one of them) there is a retractor in the bov control vaccine line. I replaced that line and the shudder went away.
so the Nissan Kompact Plumb Back isn't adjustable ?
what about blocking the recirc ?
if you can tune it out with the dual port, it must be the recirc pressure causing it
Edited by conan7772
i changed from Blitz plumb back --> Stock BOV --> Turbosmart Kompact plumb back
Blitz is adjustable with soft spring --> has shudder (pigeon sound)
Stock BOV --> big leak over 17-18 psi
Turbosmart kompact --> has shudder (pigeon sound)
i did some changes below:
1. keep BOV vacuumto plenum (no.1 in screenshot)
2. join stock ECU boost sensor with stock boost gauge sensor together and connect to plenum (keep using stock boost gauge sensor vacuum (no.2 in screenshot)
3. using a long vacuum pipe connect from stock ECU boost sensor vacuum source to intake pipe (share with stock boost controller solenoid) (no.3 in screenshot)
that could slightly reduce the shudder but can't 100% sort it.
A tune can sort it to some extent, but it really needs to remain plumbed back to the intake, or the afm will misread the airflow and dump fuel. You need a MAP ecu to vent atmospherically without affecting the tune.
You can block the bov but you will get sick dose, and probably snap the turbine off it's shaft.
No shudder on mine since the first tune, I have had the Kompact on for 5 years now, very reliable and quiet with the stock airbox.
Jesus Christ, All that extra wiring and lines is hurting my brain! Don't you at least try to hide extra wiring in your engine bay?
Why have you connected the BOV to the wastegate pressure reference line?
The BOV needs a pressure/vac signal on the engine side of the throttle body. Without vacuum; the BOV won't open when the throttle closes.
I put a grub screw in the OEM BOV bypass, no sick dose sounds and no studder, but that could be because my Hypergear SS2 is currently hella laggy. Did pick up a noticeable improvement is response with an extra 2psi at the same boost setpoint.
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
