So my car has gone through a bit of a transformation and I've got parts taking up space in my garage.
Parts are located in Blacktown but I do travel out to Greystanes and Macquarie Park
Parts are pick up only
**Stock Parts**
Cams - $50
Cam gears - $20
Cam covers + backing plate + timing cover - $100 (will not separate)
Neo engine cover - $20
Intake manifold + throttle body - $50
Washer bottle - $10
Stock shocks (slight leak) - $150
Stock front and rear sway bars - $100
**Aftermarket Parts**
Unknown brand front mount + piping - $120
Power FC with hand controller (non d-jetrio) - $800
HPI dump + HKS exhaust - $400
Nismo ratchet type oil cap - $50
Brand new unopened Nitto RB26 clear timing cover - $120
There are probably a few more parts but can't think of them off the top of my head
Currently at work and will be for the next few night so I will post picks when I can
https://www.sau.com.au/forums/topic/460351-nsw-rb25-neo-parts/
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
