Awesome. I was going to change fuel filter anyways. But you recon take fuel line off from front of the fuel rail? How much petrol should I put in to flush it out?
Run through what is in the tank first. Then add a smallish amount and run that through, then repeat. No point adding good fuel to bad in a 50/50 mix and then running half of it through leaving a 50/50 mix of old and new behind.
Keep in mind though that running a tank to the bottom can and will pick up crap from the bottom of the tank, pulling it through the pump (which might not appreciate it) and definitely putting it in the fuel filter. So don't change the filter first, and be careful about how low yo run the tank. It can of course be hard to know how much fuel is actually in the tank!
Just rereading your original post and you said you connected the battery the wrong way. I would get that ECU checked to make sure you didn't fry anything inside when you through voltage up the wrong way considering your lack of spark.
Also I would pin out the coil pack loom and make sure the coils that aren't firing are actually getting power from the ECU.
so i just did a compression test..not looking so good. i dont know exactly what this means but i cant imagine it being good that a few of the cylinders have low compression.im hoping i just didnt put the gauge in properly but im fairly sure it was in properly each time but not 100% positive.didnt have time to retest them all since it was getting too dark. but i put the new spark plugs in. didnt get a chance to test the fuel side yet..of theirs any point now :/
should mention that i haven't changed oil or the oil filter yet. could this cause lower compression ? im guessing it wouldnt make a difference.
google time !!
hrrm im hoping nothing to major. im just reading a few things on google. someone said to put a tea spoon of oil into the spark plug hole of the cylinder with low compression and redo the compression test and if its higher it means the rings are worn out and if it doesnt go higher then its the valves. least thats what im getting from what im reading. i'll redo the cylinders that had low compression tomorrow in the morning.first normal then with a bit of oil in it
yeah i noticed it was the ones next to each other. would that mean head gasket was stuffed before i got it ? or just from sitting ? i;ll be pissed if thats how the guy sold it me
lol - must have been typing at the same time.
answer is yes it could be the HG between the 2 low cylinders
ah now I see GTSboy is on the case above yours
Edited by Sinista32
somewhat freaking out lol. not giving up yet. worth getting a new head gasket? should i try the oil in the spark plug hole first or not bother and get a head gasket
Head gasket is easy fix but not so much if you don't know what your doing. It's a lot of work but not a lot of cost [emoji41]
Find a decent workshop nearby and get a quote to change it for you.
yeah i dont think i would risk doing that part myself.i've seen it done years and years ago but dont want too stuff it up. i might start googling it and watching some videos and then i'll decide if im capable of doing it on my own lol i'm hoping my cousin will come down with his g/f who's an apprentice mechanic. they're both into the nissans but not sure on their skill level. cant be worse then me though lol i'll get onto him though.looking for a head gasket now. any recommendations ?
yeah i think i;ll do the oil in the spark plug test and see if it raises.if not then i;ll look into maybe getting head gasket. if it does rise after putting oil in the hole what would i be looking to do next ? throw it out ? lol
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
