Awesome. I was going to change fuel filter anyways. But you recon take fuel line off from front of the fuel rail? How much petrol should I put in to flush it out?
Run through what is in the tank first. Then add a smallish amount and run that through, then repeat. No point adding good fuel to bad in a 50/50 mix and then running half of it through leaving a 50/50 mix of old and new behind.
Keep in mind though that running a tank to the bottom can and will pick up crap from the bottom of the tank, pulling it through the pump (which might not appreciate it) and definitely putting it in the fuel filter. So don't change the filter first, and be careful about how low yo run the tank. It can of course be hard to know how much fuel is actually in the tank!
Just rereading your original post and you said you connected the battery the wrong way. I would get that ECU checked to make sure you didn't fry anything inside when you through voltage up the wrong way considering your lack of spark.
Also I would pin out the coil pack loom and make sure the coils that aren't firing are actually getting power from the ECU.
so i just did a compression test..not looking so good. i dont know exactly what this means but i cant imagine it being good that a few of the cylinders have low compression.im hoping i just didnt put the gauge in properly but im fairly sure it was in properly each time but not 100% positive.didnt have time to retest them all since it was getting too dark. but i put the new spark plugs in. didnt get a chance to test the fuel side yet..of theirs any point now :/
should mention that i haven't changed oil or the oil filter yet. could this cause lower compression ? im guessing it wouldnt make a difference.
google time !!
hrrm im hoping nothing to major. im just reading a few things on google. someone said to put a tea spoon of oil into the spark plug hole of the cylinder with low compression and redo the compression test and if its higher it means the rings are worn out and if it doesnt go higher then its the valves. least thats what im getting from what im reading. i'll redo the cylinders that had low compression tomorrow in the morning.first normal then with a bit of oil in it
yeah i noticed it was the ones next to each other. would that mean head gasket was stuffed before i got it ? or just from sitting ? i;ll be pissed if thats how the guy sold it me
lol - must have been typing at the same time.
answer is yes it could be the HG between the 2 low cylinders
ah now I see GTSboy is on the case above yours
Edited by Sinista32
somewhat freaking out lol. not giving up yet. worth getting a new head gasket? should i try the oil in the spark plug hole first or not bother and get a head gasket
Head gasket is easy fix but not so much if you don't know what your doing. It's a lot of work but not a lot of cost [emoji41]
Find a decent workshop nearby and get a quote to change it for you.
yeah i dont think i would risk doing that part myself.i've seen it done years and years ago but dont want too stuff it up. i might start googling it and watching some videos and then i'll decide if im capable of doing it on my own lol i'm hoping my cousin will come down with his g/f who's an apprentice mechanic. they're both into the nissans but not sure on their skill level. cant be worse then me though lol i'll get onto him though.looking for a head gasket now. any recommendations ?
yeah i think i;ll do the oil in the spark plug test and see if it raises.if not then i;ll look into maybe getting head gasket. if it does rise after putting oil in the hole what would i be looking to do next ? throw it out ? lol
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
