Taking too long to stop your doped out R chassis so you can holla at some hot ass girls on the street? Then look no further.
These came off my GTR and have only traveled 45,000kms (verified with Japanese department of transport)
What you get:
2x Front Brembo Calipers and High quality racing pads
2x Front 330mm Factory Rotors
2x New Non ADR approved brake lines
2 x Factory Brake lines
I will supply the rotors machined ready to go.
Perfect big brake upgrade for your S or R chassis. If you want to stop like a mofo, this will do it.
Happy to post at buyers expense. I *May* be able to organise cheap postage to Brisbane if you can pick it up from a Depot.
$1150, plus whatever postage comes to.
Thanks.
Edited by The Mafia
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
