They are a bolt on kit for the RB26 DETT so will fit the standard dump pipes.
Interested to replace your -9s? I went the other way.
I believe that they can be (I never experienced it 1st hand) but then it is all about application.
The -9s were recommended to me as I was wanting something tractable but it means that I make a sacrifice at the top end.
I am happy with the outcome but the previous owner of the car loved the GT-RS.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 3 months later...
  • 1 month later...
  • 4 months later...
  • 8 months later...
  • 2 months later...
wow. this is awesome buying if anyone is reading this. as a comparison, i sold my Tomei arms twins for $1500.
these turbos, bunch of gaskets and a free weekend you could have upgraded turbos for 1k.
  • Like 1
Cheers @WantGTR
I originally had them for sale at a much higher price which seemed reasonable two years ago. Things have moved on (EFR popularity etc.) but if you want to maintain a stock looking engine bay, these are an option.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
