OP6 high flow turbo for sale
Was making 240rwkw @16psi on 98 in my R34 GTT
Only selling due to going bigger
$500 plus postage
Greddy return flow FMIC suit R34 GTT
Was fitted with the above high flow
Selling due to going bigger as well
$300 plus postage
Located in Bathurst NSW
