1997 S2 R33 GTST in QM1 white
Manual
15XXXX KMs
$5000 firm
Selling due to very limited use. I have put on no more than 20k KMs in the 4 years since ownership. Has been out of rego since Sept 21 but comes with pink slip.
Has not been driven the past few months but regularly gets kicked over for a few laps up the street
Mods:
Blitz return flow FMIC
Fenix auto alloy radiator/silicon hoses
Nismo thermostat
Blitz ZZ-R coilovers (c spanners included)
Daiken HD clutch
Front and rear strut brace
Splitfire coilpacks/NGK iridium
Genuine Apexi Pod kit (Stock airbox and spare AFM also)
HKS Priest 3" cat back
17x9 +22 enkei RP01 in White
Apexi SAFC2
New battery
Alarm with built in turbo timer
Also comes with the below parts but not installed:
Viva garage front lip
3" bellmouth 1 piece dump
3" Hi-flow cat
Stock intercooler/piping
Stock airbox
Spare Pink Label AFM
HICAS lock bar
Due to my move few years back I regret to inform that can not find any documentation/receipts that I have for the car. Searched high and low and hoping they will eventually turn up.
I bought the car absolutely stock with 13XXXXKMs on it. I will try to find the ad that was originally posted up on here.
There are no known issues with the car and has never been in an accident to my knowledge. I have also replaced all manifold studs plus the manifold and turbo gasket due to previous leak. Does not leak and oil/fluids and doesn't blow any smoke. Though the air con needs a re-gas.
If you say you are going to come and take a look, please be professional about and at least let me know if you are not able to make it as I have had to take off work early, deny other people access, just to meet 'seriously interested' people that don't end up coming and not replying to text.
Contact:
Felix
0401905915
https://www.sau.com.au/forums/topic/461008-1997-s2-r33-gtst-5000/
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
