Hi all, what would it take to create a car for sound-off competitions?
I mean those crazy things that you see at car shows with heaps of speakers and subs and the like.
I've wanted to make one for a while, but other than the sounds gear, what else is needed?
I'm a little bit (Although not completely) clueless in this area, so any help would be useful.
Cheers
https://www.sau.com.au/forums/topic/461139-building-a-sound-off-car/
buy the right car first (panelvan, wagon, van, etc) then turn it into a giant sub enclosure. remove flex from all panels, seal everything up, with a shitload of expanding foam, sound deadener, bog and plywood...
then, fill it with the biggest subs possible, a crapload of high power amps with the right amount of power for the subs, good dozen of deep cycle batteries to provide the current, and don't forget all the zero gauge cabling
electrical is pretty much the same as any other audio setup, just at a bigger scale. you would at least need several batteries wired in parallel, some fat 0 gauge cabling between the batteries and the amps, upgraded alternator, properly rated fuses, a set of amps capable of driving all the speakers and subs you plan to install and maybe some capacitors as well.
i haven't done a setup like that myself, my most complex build was just a standard head unit/splits/pair of coax/two amps and a sub so wouldn't call myself an expert
Edited by junkie
Fair enough, what do you think the ballpark would be for all gear, excluding the car. Like 3-5k?
3-5k will build a decent oem replacement system with some good quality gear
but sound off, that's a whole different story. amps and subs cost a lot when pushing those kinds of power and decibel levels. plus, you would be up against some cars that have had six figures spent on the installs, so its a case of go hard or go home
I was only really thinking of it as a way to spend some time messing around, as an excuse to enter into shows and such. Not a completely nuts thing. Time to reconsider I think....
a wagon and not a coupe..
then a bunch of subs, slot ported individually and tuned using a SPL meter to see what resonate frequency the sub will peak at... each cabin is different.
I used to be into this shit 1.5 decades ago.
Fire it backwards to load it up (know as superpositioning) which will give you about a 3dB gain - approximately double the "loudness" and with careful port tuning you could pull another 2~3dB from the cabin gain.
I did 146dB with a single 12" Solobaric being fed 1.5kW back in the days however I had a 140L or so box.
I reckon a single 12" DD Subwoofer with about 1kW going to it will push you past 145dB easily in a ported box and if you feed it more it will make even more power.. downside is these subs don't go low and need huge boxes.
http://www.ddaudio.com/products/mobile-audio/woofers/dd9500
Question is, what is your goal and what is your budget?
You can go loud on a budget but you'll need at least a decent subwoofer/driver... get a pair of Jaycar monoblocks and strap them together
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
