Hey Team,
I'm trying to eek out the most from my set of Hankook soft 221's. I'm hoping to get one more trackday out of them....
They have done 3 track days... 2 of them wet. (in the last 9 months or so)
I have another coming up on the 17th Dec at the my usual track, Wakefield.
Now the question is what would you run on the front and back? As you can see they are marked for RF LF RR LR.
The Rears are very low and the fronts have started to melt.
Should I keep running the fronts where is, to make the most of the grip for turning or put them on the back and get drive?
Seems obvious that I put the ones with the most tread on the back, but Wakefield is such a tight turning track.
They are on an R33 GTR.
Thoughts?
https://www.sau.com.au/forums/topic/461149-semi-slicks-what-would-you-do/
haha I think the opposite....if you take softs to a track day at wakefield in December you will destroy them. probably in the first session. so it doesn't matter which one goes on which corner :P
keep those for hillclimbs or super sprints, and go and buy a set of medium or hard tyres instead.
  • Like 1
Hankook Z221 softs (C70) are like Yokohama A050 Mediums. Maybe a fraction softer, but not alot.
I've done a hillclimb, 2 Lakeside days (1 over 30 degrees ambient), 2 days at Morgan Park in 33 degree heat and 1 day at Phillip Island on a 1530kg Soarer. Tyres are about half worn except for the outer edges. I was planning on flipping them on the wheels to maximise their life, but I think the rear tyres may have gone off now - I had no rear grip at the last track day and it got worse with each lap... I should have changed them front to back to see if the problem moved with the tyres, but CBF. It was too hot
A couple of mates who run Hankooks have had the same thing happen - they go off before they wear out.
Edited by hrd-hr30
Good to hear, I haven't used them myself, I was just going off my experience with other soft tyres
In that case, bang them on any corner, have fun until lunch, then check them for rotation for the afternoon. I'd always put the best tyres on the most loaded point which is front left at wakie....you can always control the amount of rear wheel work with your foot....
  • Like 1
yeah, but if you don't know what they're like brand new, you can't really say they're consistent down to the belts. Mine ran effortless 59s brand new. Now at about 50%, 1:01.2 was all I could do. Might be why that bloke was selling his... They're still faster than Nittos, but nothing like what they were new.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
