DO NOT RUN ANY EBC PADS!!!!! if you like i can cut some planks of wood you could run that would work a tad better. Jus get some DS2500 work horse pads for the rear
What a load of crock.
EBC Yellows, rated to 900 degrees not good enough? Or Reds rated to 650 degrees?
But you recommend a pad that's rated to 500 degrees? Did you know Green stuff is designed for kit cars up to 850Kg and also rated to 500 degrees? So if you ran them in a Skyline, im sure you would know why they didn't work well.....
We run lots of cars on Yellows, no fade issues so far, only issue is finding enough cooling and a rotor that can keep up with them.
LOL, i stated an opinion...
Say what you want about temp ratings. I am not arguing as I have no idea what their temp ratings are. My gripe is I don't like the pedal feel and they require a load of pedal effort. Best analogy is wooden.
My comment "I do loathe EBS green, red and yellow pads. Some like them but i think for track they are actually a rather rubbish performing pad, with poor feel to boot. But they are cheap and perfectly fine i guess for a spirited street car
You say we run lots of cars..do you work at a brake place? Where? Not being a smart ass but have you driven similar cars with different pads to actually compare how they feel and perform with.
I've found temp ratings mean 2/5ths of f**k all in a lot of instances.
Where by you'd think two pads both rated to around the same temp should last around the same length of time - but that is certainly not the case.
Example A might last 4 track days where Example B will be cactus after a single outing... Identical cars.
Now maybe the compound is different etc, but generally I've found if you are destroying pads (basically, disintegrating them) then you're going outside their "temp rating" and hence the breakdown.
Temp rating is fade resistance.
Separate that from lifespan, 2 different things.
Just as you can separate it from the aggressiveness on rotor wear.......
See I've found that to be all over the place too (the fade). Given there are loads of variables in that scenario, cooling etc.
You would think though one pad shouldn't massively wear faster than another in a certain region of performance. I know the A1RM when tracked, get eaten up like butter even on 1300kg cars and they are 780 degree or whatever.
Ah brake pads, such a PIA :D
  • Like 1
Nothing is directly wrong with them. I feel the balance is off. Trying to brake from 4th to 1st, or on a sweeping turn, the rear gets very light, and sways. When braking into a sweeping turn, it gets very squirly.
The K-sports in the front are 8-pot 356mm i believe.
How low is the car and is your HICAS locked out?
  • 4 weeks later...
Update:
Installed Ferodo DS2500 front pads, Stoptech Rear Rotors & hawk pads. Have not hit the track, or gotten too agressive on them yet. my front right Screaches like hell on a slow stop. But they do bite. I am waiting for a new set of rotors for the front.
Car is not slammed, tires dont tuck. I have the pineapples installed, so the lowered to be geographically correct. HICAS is locked out.
Alignment is -1.1 all around
2500s shouldn't squeal at all, mine didn't when I had the GTR and now in the HSV.
That said, if you put them old rotors, that'll be partly the reason. Make sure you put the anti squeal shims in etc.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
