Hi,
I recently got my R34 25GT Coupe and want to change the exhaust so I can make it louder but not too loud so it sounds off putting.
I'm a P Plater in Victoria, I hear I can only change the rear piping after the cat for it to be legal.
I'm not too sure what to look for exactly, been looking around for days with little luck, so can someone please point me in the right direction?
Thanks,
Jesse
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/
Hi, and welcome to SAU, the best place in the world for all things Skyline.
According to the Victorian "P" Plate laws, any vehicle (Even Mum's Camry) can be considered prohibited if it: "has an engine that has been modified to increase the vehicle's performance (other than a modification made by the manufacturer in the course of the manufacture of the vehicle"
This means that exhaust mods are basically off the table for P Platers, as even a cat back, like you mentioned could theoretically give performance gains. Still, many do it anyway. (A cat-back on an N/A would give very small, even possibly non-existent gains)
If you still want to do this, try to be a bit stealthy about it. (An R34 with P Plates on it is already a cop magnet, regardless of modification level)
I personally suggest ringing up or emailing your local exhaust shop, and getting a quote for something made up and installed, as most popular brand made bolt on systems systems are for the GTT (Turbocharged) model.
Completely avoid the cannon, and try to stick to the stock twin tip look, to avoid attention from anyone unwanted.
Maybe look into getting an X-Force Varex muffler, which allows the volume to be controlled if you want to keep quiet if need be, to avoid unwanted attention.
The RB25 sound can actually be quite nice, if done properly.
Good luck with your R34.
Edited by Burger
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7642192
Thanks Burger, I'll have a look.
To get a good sound, do you reckon I should look out for a muffler with a 2.5" inlet and a 3" outlet?
I found a single tip and double tip that look alright but not entirely sure what I should look for when referring to sizing.
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7642214
Awesome. How much all up - $550? It's the first mod I did on my N/A back in the day. Very handy passing cops, going through RBT's, driving inlaws, being taxi boyfriend, talking, etc.
With mine, adding a pod makes a difference to the exhaust sound. better inhale = better exhale. or maybe a high flow filter will work on your airbox. I never tried it though.
Both is illegal here in NSW too. I got away with it for 3 years and I got defected for Pod filter. They said nothing about the exhaust. Now using the airbox since that day and my GF driving it now.
Just don't spend anything else until you get turbo skyline, you'll need the money, trust me! been there done that! :P
Goood luck
  • Like 1
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7646885
Yeah it was around 700 really, paid a bit extra to get it done properly considering I went to a few places that said they couldn't do the job.
I'd love the turbo but I'm not sure if I'd be able to make the extra money for when I get off my p plates.
Would love a garage too, less likely to be keyed!
https://www.sau.com.au/forums/topic/461200-na-r34-coupe/#findComment-7646948
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
