  • 4 weeks later...
two or three?
this week, brasil and abu dhabi?
also i guess nico... as i think its the lesser of two evils...
i mean i used to think nico was alright, but his driving this year has seemed like he doesnt want to win...
Edited by MatthewT85
Whats funny is if Nico gets up the haters will say it was becaise of unreliability. But Hamilton seems to be fine with a WDC from when Massa blew up whilst in the lead with only laps to go.....got lucky with rain on the last lap in Brazil etc.
Just like when Nico had a throttle problem in Singapore yadda yadda...the more vocal English press gloss over the fact that Nico had problems in the race that he managed whuilst Lewis had problems in practice and quali etc
Anyway, I dont care so do remember all the details. Not like the Webber - Vettel years :)  I almost want Nico to have a DNF due to gearbox failure and then beat him with two wins in the final rounds!
Good race. Many lols.
Verstappen gets a penalty for the same thing Hamilton gets away with.
Verstappen won't redress because he wants third.  Then gets penalised and drops to fifth.  Then gets promoted to 4th which is where he would have been had he redressed.
Then Lauda pours a bucket of shit on him.
Vettel goes postal and gets nothing.  Moves around under brakes and gets spanked.  Good good.
Rosberg looks like he will cruise around in P2 to the wdc.
Hoping like hell the new rules for 2017 will include some interesting racing for the lead instead of p3 at best. Newey looks to be half interested again.
Farcical 1. All those penalties were a joke. As were all the drivers comments during and after the race.
Seems if they're not handing out 40 place grid penalties they find other ways to keep themselves occupied - in this case by artificially modifying the podium
Bernie should start watching some MotoGP to see what real, exciting racing looks like. Not only is f1 boring as watching paint dry these days, cocksuckers like verstappen get f**k all penalty for shit, while vettel cops it for doing less than verstappen has done 50 times in every race this year...
LOL at Dezz - jilted Ferrari fan. Don't worry they will win again and you will love F1 again. Might be waiting some time though.....
It's actually got nothing to do with who is or isn't winning, the sport is actually boring now. That's coming from someone who still doesn't miss a minute of quali or a race... The moment there is some action, there's a stewards review and someone's penalised...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
