96 R33 GTR vspec series 2
rebuilt rb26 short block
reconditioned head
Tomei 1.2mm head gasket
new oem gaskets everywhere else
Tomei 1.5mm oil restrictor
Gates Racing timing belt kit
n1 water pump
reimax uprated oil pump
front mount intercooler
plazmaman rb26 fuel rail
turbosmart fpr2000 fuel pressure regulator
2000cc xspurt injectors
hks evc5 boost controller
trust greddy td05-16g twin high mount setup with screamer and braided lines running gate pressure
custom 3.5inch exhaust
custom hot side turbo pipes
Custom Washer bottle / Oil catch
Vipec v44 ecu on safe tune running E85 at 335kw at the wheels dyno sheet to prove
needs a final tune and will see upwards of 350kw at the wheels
walbro 044 fuel pump
bigger fuel filter
nismo coppermix twin plate clutch
nardi sterring wheel
standard r33 gtr vspec brembo brakes
light weight rpf1 wheels in black wrapped in kumho semi slicks
coilovers
registered till august 2016 and plates come with the car
car will come with a few extras for the buyer at the right price
extras include
hicas delete bar
biig greddy oil cooler
carbon fibre front grill
also have the standard steering wheel with airbag
i might have forgotten a few things just remind me if i have thanks
PRICE: $27000 O.N.O
if you need to know anything else text me on 0417 136 746
Edited by samrazor
https://www.sau.com.au/forums/topic/461936-syd-96-r33-gtr-vspec-series-2-e85/
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
