SAU Nickname - Snowman
Car Make and Model - BMW 135i E87
Circuit Name - Nurburgring - Germany
Lap Time (BTG) - 9.12.3 :) - Google Earth file of lap here - http://sau.ferni.net/Snowy/20080404-1505-b...ap-1-export.kml
Mods - Half cage, Sparco Race Seat and harness, Brembo Brakes and pads and KW Suspension
Tyres - Bridgestone RE050 street tyres.
Power - 306HP
I did one slow sighting lap to see the track and get a feel for the car - which scared the crap out of me.
I then did my 1 hot lap - which really scared the crap out of me.
On my next lap it started PISSING down and then a car infront of me speared off into a wall halfway around the track and with me having a $20K excess over my head I decided it was time to call it a day. (My lap time in the rain was 10.51).
But my god - what a track that place is!
So jealous... I really regret not doing the burgerring while I was over there...
Same here.. I was over there for 2 years and it did not even enter into my head that I should goto the ring.. how f'n stupid of me
Dam snowy!!!!!Well done mate!!!!
Is that the twin turbo bmw? (same motor from the 335?)
Has anyone else here done the ring? A mate did it in a renault megane and was around the 10min mark
Yep - same twin turbo motor out of the 335i. I originally booked that car as I thought it should be fun and light and nimble. When I got there on Friday morning Theo (who runs rent-racecar) told me I had picked the "most difficult to drive" car in his fleet. LOL. I soon found out why. Because it has pretty good power but it as quite a short wheel base so it was EXTREMELY twitchy in the rear - espeically at higher speeds. And there are plently of places you find yourself having to brake and turn from high speeds and boy did I have some moments! Still - no point in not making the most of a potentially one off life experience hey. :D
BTW - Theo told me I was insane to have run 9.12 on my 1st ever lap around the place. lol
  • 4 weeks later...
SAU Nickname: Dave R (David Rodan)
Car Make and Model: 99' Honda Integra R (DC2R)
Circuit Name: Wakefield park (Re-surfaced)
Lap time: 1:11.5
Modifications
Engine: Exhaust, extractors, intake.
Power: aprox 105-110kw @ wheels
Suspension: Buddyclub Race Spec Coilovers, Buddyclub P1 Camber Kit F&R
Tyres: Dunlop D03 (semi's)
Brakes: Project Mu 500max, Slotted Rotors
Body weight: 1175kg (full tank of fuel and me)
Weather was interesting, was raining on and off during the morning and the track was fairly slippery for most of the day.
was done on 27/4/08 Round 2 of NSW SS...
http://www.natsoft.com.au/cgi-bin/re...4/2008.WAKE.SS
Yer yer i know its not a skyline :(
Edited by Dave R
SAU Nickname: Duncan
Car Make and Model: 32gtr n1
Circuit Name: Oran Park
Lap time: 49.7193
Modifications
Engine: standard n1
Power: 240awkw
Suspension: noltec coilovers
Tyres: yoko a048r
Brakes: standard brembos
Body weight: 1550kg
done at night too!
Beat my PB at Winton by 3 seconds today with 35rwkw less than before at 1.41.7-ish
Damn, I know my lines arent the best, and im going in a bit too hot on some of the corners, but I dont think theres more than 2 sec's in it (at my level of skill) unless im doing something really wrong.
Wonder how much time there is in it if I get a proper wheel alignment and some strut braces and sway bars. No matter, I wont be doing anything else to it until get into the 30's. No point spending more money to make up for the lack of driver skill :)
Edited by Yawn
The car has 280rwkw and Ohlins coilovers and RE55s. I need a wheel alignment, havent done it before, and some sway bars and strut braces might help a bit.
The first time at Winton I did 1.44-ish, which was the time before this. I had 315rwkw at that time with RE55s and GAB coilovers.
Im not that satisfied with the time because of me knowing quite a few drivers in their stock-ish evo's in the 38-39s. And your time too Roy, thats what I call respectable. You've got less power than me but presumably more suspension work?
SAU Nickname: BHDave
Car Make and Model: 32gtst nugget
Lap time: 1:07.9310 (natsoft No 12)
Modifications
Engine: rb25det
Power: 255rwkw for the moment
Suspension: cusco comp 2 coilovers, Whiteline 24mm front and rear bars yadda yadda, same as last time
Tyres: 235/45 17 RE55 well past the indicators on the rear
Brakes: R34 GTT front with pmu hcr pro rotors and HC+ pads
Body weight: Stock minus AC compressor, back seat and boot trim. GTR bonnet and front guards
Natsoft arvo standings
So Boz pulled a 1:05 out of the southern motor works exige today (running slick i might add....), does that mean my car has a low 6 in it as it stands? :D
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
