Hi,
I have a 1990 R32 Gtst, 5 speed manual for sale. Asking $3k and take it away.
The only reason for selling the car is that I need some space in the garage and I don't have the time to complete the car.
The car runs well and is 90% standard. It would be perfect for someone looking for a project or even just for parting out.
I've owned the car since 2006. It has approx 184,000km's on the dial.
The car has been meticulously cared for. It has only been driven twice in the last 18 months but is started regularly.
The car is currently in primer with some of the rear interior trims removed, otherwise the car is complete and runs perfectly.
I've got a spare straight through exhaust for the car in addition to the exhaust already fitted.
Car is currently unregistered so collection of the vehicle would need to be on a temporary permit or picked up on a flatbed.
Located in Carrum Downs, Melbourne.
Cheers.post-51802-0-65127600-1451896753_thumb.jpgpost-51802-0-22165700-1451896768_thumb.jpgpost-51802-0-39716200-1451896803_thumb.jpg
https://www.sau.com.au/forums/topic/462024-r32-gtst-for-sale/
  • 4 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
