MMmm ok, I bought this car with a 3 inch straight through already on it.
It has the large twin tip Jasma muffler.
As much as I'd hate to say it , it's just too loud.
Giving me a headache with every day driving.
I reversed up a steep driveway early last Saturday and woke up the whole street.
The deep growl at low rpm is awesome, but mid range ..... :yucky:
There's a crackle that just echoes off everything I pass.
So can anyone suggest a muffler that will have minimum loss of power, no drone and still a nice sound.
Forget Varex Xforce, aint gonna waste $500 on a muffler..., plus extra $$ on install
cheers
https://www.sau.com.au/forums/topic/462026-m35-performance-exhaust/
Fujibitsu legalis R is by far the best system. Straight bolt up proven to flow over 300kw atw and a nice sound with absolutely no drone and is legal volume. If you get one and need it fitted bring it over and I'll bolt it up.
^What he said
I swapped my stock variable system for a Fujitsubo and made a huge difference and highly recommend it.
If you are interested in my old system I'm happy to sell it. It's a factory variable system
Mine looks the same as Luis.
What's the deal with the second mid muffler ???
Does is act as a resonator or something ?
I'll put it up on ramps and take some pics tomorrow..
Thanks Josh for the offer mate
Edited by conan7772
I'm assuming twin tip is louder than single.
Twin tip is designed to flow faster ??? Less time for sound to be absorbed..
I think my muffler is slightly larger than Luis and completely hollow.
I put a stick in there and couldn't feel a thing.
I'll take some measurements tomorrow and db test it.
Edited by conan7772
Mate the varex systems are way too loud when open and so restrictive when closed. These engines have such loud low rev engine sound and its hard to make an exhaust that is not loud.
Ive had aa apex-n1, straight through with varex, fujitsubo legalis r and now a kakimoto hypermega and have to say that the fujitubusu legalis is the quietest followed closely by the kakimoto hypermega n1. If you can get your hands on either of these systems you will be more than happy.
Loudest system ive had is the apex-i N1. This thing can be heard from like 4 streets away.... stupid loud
Edited by joshm35
This is my old system next to my new one
This is actually a stock V35 coupe mid section joined to the stock M35 rear muffler... The stock V35 sedan/M35 Stagea is about 10 times bigger...
It is a cheap change quick change over that is a tonne lighter and does make it sound a little bit nicer than stock... And yes, I did this mod... :-)
I wondered why the mid pipe always looked different to other stock M35's exhausts I have seen. How was the droan compared with the V35 mid section after you swapped it
There was none...
Was able to use bluetooth device clipped to sunvisor without any problems before and after changing the mid section. I ran it with the coupe mid section for a couple of years and around 25,000km. Sold the car with it, and pretty certain that the guy who bought it also left it on there.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
