  • Replies 92
  • 4 months later...
I have sold my last R30. Now only have An R32 and two Stageas.
I have for sale an R30 workshop manual $50 plus postage.
Also I want to clean out the R30 parts. There are doors, bonnet. mud guards , alternator, starter, 4 head lights etc, several boxes of bits.
All the stuff is here on Mt Tamborine, and it is for FREE, PICK UP ONLY. You will need a ute.
PM me if you are a needer.
PS> The rear doors do not have the window switches, but are powered
Edited by 66yostagea
  • 1 month later...
  • 4 weeks later...
Okay guys the rally c210 arrived and i need afew parts for it in order to get it road ready.
Need front seat belts
Front blinkers complete
Window winder handle
R180 Diff - May of found one but will always take another.
I"m located on the Central Coast, NSW
Hey, Welcome to the classics section!. good to see another C210 in the mix.
have a look in the wreckers, or gumtree, or ebay dude there are very few of these cars around any more so to be honest I can't imagine too many people are likely to give parts up for a car thats going to be thrown through a forest, in my opinion(and it is just my opinion) tidy it up a little, respray it and have a nice, tough street car(assuming its got a decently built engine)
To me, rallying something so rare, just isn't right. Those bumpers and bonnet trims are so straight! Do you know how hard it is to find parts in that condition?
Anyway, nice car, and like I said, Welcome, enjoy your stay!
Cheers
Jason
the bumpers are bent, but all other chrome is good. The car wont be a dedicated rally car, it will be road registered and will be a daily driver so i will be looking after it, hillclimbs and sprint events are my main target, i would much prefer tarmac events than dirt but its setup for dirt at the moment so i'll be using it like that until i can change it to tarmac setup.
  • 10 months later...
  • 6 months later...
  • 1 year later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
