Hi
I have a 2015 r35 gtr
I've had a few mods on it done by jim at Croydon racing developments
It's got croydons own y-pipe and Cobb access port v3 with tcm
I'm looking else where because I feel like I'm getting the runaround and being overcharged
I want to put a turbo back exhaust preferably 4 inch and also a retune using Cobb
I'll also need advice about fuel pumps, injectors, spark plugs and cold air intakes
Thanks for looking
https://www.sau.com.au/forums/topic/462146-looking-for-a-good-tuner/
  • 3 weeks later...
Have a chat with Martin @ Willall. He can very well send you an etune + Cobb, then run a few 4th gear 60-180kph logs and he will fine tune it. Willall is definitely the way to go, hands down, no questions. I have drop in HKS filters, HKS Superior Spec R Ti exhaust and Willall titanium mid pipe and running the 2009-2010 refresh etune. They have perfected their Advanced Traction Control as well as BOTL and Rolling Antilag. These can be added to the tune on request. The ATC is well worth the money alone! Totally satisfied
Edited by Wardski
  • 3 weeks later...
Powertune
Unigroup has a 2WD dyno unless you're willing to pull out the front shaft or raise the front on jack stands (highly not recommended).
4WD should be installed by now. They bought a new one.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
