Hi,
Been a member, stealing ideas and advice silently from the shadows for a few months. This is my 1st post so be gentle and use some lube. I've simply been recording my progress with my 33 4 door doing some motorsports with plans for more, much more. intending to run Time Attack QLD series and such as well as a few hill climbs and other miscellaneous events and the odd skid here and there to fill in the gaps. I've been uploading the vids of what I have been doing to YouTube so figured I'd share the link here, seems the people most likely to be interested. Saves taking heaps of pics and writing it all down, just put together a vid and let the google corporation store it in the public domain for me. I'll share a couple of links, will depend on what you interested in, if anything as to what you might want to click on. Remember, I'm learning as I go, my 1st skyline and track car, so mistakes are made, but left in as part of my learning progress, and you might not make the same mistake if you see me do it.
1st Episode, a bit cringe worthy but it's where it starts, this and the next 2 sorta tell you what I have to work with. https://www.youtube.com/watch?v=Qez549XL2s
28th Episode, A few skids at QLD raceway, if that's your thing.
29th Episode is the 2015 Jap Nats.
I have no idea if those links will work as I had to type them in manually? I assume it's a bot prevention thing?
Anyway, figured I'd share, if you like it well great, if you don't well good for you too.
  • Like 2
  • 4 weeks later...
Well I must say I'm overwhelmed by all the comments lol. Regardless... Here is the latest event vid.
https:/www.youtube.com/watch?v=MWBGL5ug6F4
Plenty of build vids to go with the event vids, I just find the events are a bit more watch worthy as the car is being driven, as opposed to worked on. But if the build stuff is your thing please do like, subscribe and other stuff... I think share is the other thing you're supposed to ask for on youtube lol.
Anyone able to tell me why I can't make this link work.... would be helpful.
Edited by Tangles01
  • Like 1
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
So Jap Nats was on a couple of Months Ago... I could have gone much better
On 12/08/2016 at 8:22 PM, Shoota_77 said:
Great to see someone getting so much use out of their car, good on you! Hopefully my car doesn't know how to use YouTube, it might get a bit jelly....
Thanks man, I think you car might think itself lucky it doesn't get the abuse too
  • 4 weeks later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
