Hi all,
I’ve owned this car for a few years now, barely drive it anymore and think it’s time for someone else to enjoy it. I had to fix a few things mechanically when I first bought it as it was starting to show its age, particularly in the steering and suspension bushes as well as some weeping front seals. I’ve ended up with a car that turns and stops properly, doesn’t leak oil and is very reliable. The car came with a pretty good record of maintenance and a few junk parts that I have since replaced. Cosmetically it’s still a little rough around the edges, the body is pretty straight with a few scratches, its had a respray at some point in the original colour and there are a couple of bits or rust starting to show under the drivers side rear window and in the spare wheel well. Interior is original with the usual standard features, clock doesn't work, bubble in the dash and B pillar trims coming away. Anyway, here’s some details and photos.
Engine and gearbox:
Internally stock rb26 with long nose crank
Apexi power FC
HKS 2510 turbos
Nismo AFM’s
Nismo fuel reg
Nismo Twin plate clutch
N1 oil pump (less than 1000km old)
Trust Type R BOV recirc’d
HKS 100mm intercooler and hard pipe kit
HKS big mouth Stainless dump pipes
RSR twin 70 to 80mm front pipe
Sard 800cc injectors
Splitfire Coilpacks
Blitz Dual SBC boost controller
Ross Tuffbond harmonic balancer and modified power steering bracket to line up the belt
Gates adjustable cam gears
K&N Filter in factory airbox
Metal Cat
3 inch exhaust with big RSR mid and rear mufflers
Walbro 500hp in tank fuel pump
Genuine Nissan timing belt, new tensioners and seals installed less than 1000km ago
Suspension and Brakes:
BC Coilovers
Full Hicas delete (all lines and solenoids)
Drift Works Hicas Eliminator and adjustable toe arms
Drift Works adjustable rear upper control arms
Subframe lock collars
GKTech Front roll centre adjusters
Tuneagent adjustable front castor rods (less than 1000km old)
Interior and Exterior:
Nardi Steering wheel with HKB boss kit
Nismo Gear knob
HKS boost gauge on A pillar
2wd/4wd controller
East Bear copy skirt extensions
BBS LM 17x9 +20 wheels and 255/40-17 AD08 tyres
And the air conditioning works.
Looking for $20,000 ono as it sits.
Rego til July 1st
Located in Campbelltown NSW
Contact via pm
https://www.sau.com.au/forums/topic/462496-syd-fs-1994-r32-gtr/
could be a gem at the price. looks ok from the pics.
Leakdown and then put the ears on it
3 piece Nismo/N1 side skirts and BBS rims
its like getting a few chips with your takeaway :)
Nismo Gear knob
2wd/4wd controller
Not N1 side skirts as it seems.
East bear copies hmmm. 3 piece and all
at a glance they fooled me :(
I couldn't see the east bear copy extensions when I looked - Doh!
I was obviously looking at them the whole time
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
