Adam,
A Borg Warner EFR8374 matches most of your requirements. Rated up to 800HP (79lbs/min compressor) and capable of well over 400kW at the rear wheels on E85. Available in 0.83 A/R T3 internal WG.
Garrett's GTX3582 is available in a T3 twin scroll but only external WG. However they do have a T3 0.82 internally gated turbine housing. It will produce less power than the EFR8374 but probably provide slightly better response.
Here's a back to back comparison between the smaller Borg Warner EFR7670 with a T3 0.83 vs. a Garrett GTX3582 T3 0.82 on a 2008 model STi running pump fuel with 50/50 water methanol injection:
Opt for the 400kW car... you know you want to :yes:
  • Like 1
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7688077
There are other options that will meet 'most' of your requirements. But not many available with an off-the-shelf T3 internally gated exhaust housing.
Precision Turbo (Shaun is familiar with PT stuff) PT6062 CEA GEN2 (rated up to 750HP) is available with a T3 5-bolt housing which could be set-up to run internal WG. A little bit of stuffing about though.
Forced Performance have their new Xona Rotor range, which is basically their previous FP comp/turbine wheels with a new CHRA. But no off-the-shelf IWG option.
If you switch to external gate your options increase significantly.
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7688262
6262, comes in a ford 1.06 in gate housing option ..which means a 6062 should fit aswell....
or people get them machined into the ford housing..so im guessing you could machine it into a .82 3582 in gate housing..?
cheers
darren
Edited by jet_r31
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7688347
  • 4 weeks later...
Stock manifold will be a choking point, you need the motor to breathe.
If you want stock manifold, get a fabricator to run twin gates off it.. grouping cylinders 1~3 together and 4~6 together.. the factory manifold surprisingly is "nearly" twin scroll, bar that little notch.
OR use a Havoc Fabrication modded manifold which merges each of the pulses into 1x gate. I would expect at least a 45mm or 50mm gate off it.
GTX3582 would be perfect, especially with that 3.0L pushing it along.. heck even a GTX3576 would be perfect.
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7700787
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
