Jc052685 Posted February 18, 2016 Author Share Posted February 18, 2016 This was a year ago on 13psi and pump gas (and i guess it was 480whp) Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685291 Share on other sites More sharing options...
Hadouken Posted February 18, 2016 Share Posted February 18, 2016 1000cc injectors is way to small for 500kw on e85..... Or at least a Aussie 500kw that is. 3 Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685294 Share on other sites More sharing options...
Jc052685 Posted February 18, 2016 Author Share Posted February 18, 2016 So what will 97% dudy cycle on ID1000s on e85 get you guys? Though it was actually E70 Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685297 Share on other sites More sharing options...
Hadouken Posted February 18, 2016 Share Posted February 18, 2016 400 ish kw Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685298 Share on other sites More sharing options...
Jc052685 Posted February 18, 2016 Author Share Posted February 18, 2016 Interesting...I asked in the other thread but..... do you guys trust Mainline dyno numbers? Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685300 Share on other sites More sharing options...
GTR_JOEY Posted February 18, 2016 Share Posted February 18, 2016 400 ish kw Even that's pushing it Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685301 Share on other sites More sharing options...
mr skidz Posted February 18, 2016 Share Posted February 18, 2016 yepSo you're restriction remains present. Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685307 Share on other sites More sharing options...
Jc052685 Posted February 18, 2016 Author Share Posted February 18, 2016 The restriction being what? The inducer its self? Restriction would be anything befor or after the turbo that would hinder flow. Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685311 Share on other sites More sharing options...
XKLABA Posted February 18, 2016 Share Posted February 18, 2016 Lifting base pressure 15oddpsi will see more flow for more topend What C/R is it running Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685313 Share on other sites More sharing options...
Hadouken Posted February 18, 2016 Share Posted February 18, 2016 Even that's pushing itI was being nice 2 Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685316 Share on other sites More sharing options...
Jc052685 Posted February 18, 2016 Author Share Posted February 18, 2016 Lifting base pressure 15oddpsi will see more flow for more topend What C/R is it running You talking about raising the fuel pressure? Its already at 58psi. Figure another 25psi when under full boost you are looking at 83psi rail pressure. Not sure on cr Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685318 Share on other sites More sharing options...
mr skidz Posted February 18, 2016 Share Posted February 18, 2016 The restriction being what? The inducer its self? Restriction would be anything befor or after the turbo that would hinder flow.Yes the inducer and compressor cover inlet. Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685322 Share on other sites More sharing options...
mr skidz Posted February 18, 2016 Share Posted February 18, 2016 (edited) You're making more power at your engine flywheel then the turbo can flow on a test bench on its own with no restriction in front of or behind it, see what I mean? Edited February 18, 2016 by mr skidz 1 Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685325 Share on other sites More sharing options...
Ants Posted February 18, 2016 Share Posted February 18, 2016 1000cc injectors is way to small for 500kw on e85..... Or at least a Aussie 500kw that is. This ^ I made 604hp with my -5s on my Tomei motor at 27psi (still 2.6) on E85 with 1,000cc injectors twin bosch pumps and a Walbro 460 lift pump (to surge tank) and they were almost maxed out Most GTR-s that run -5s here in Oz make between 450-480kw max on corn syrup I think dyno read out is a bit too optimistic IMO but we all know how to settle this don't we? you will need a drag strip and a go pro and a pic of 400m..........wait..........I mean quarter mile timeslip 3 Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685332 Share on other sites More sharing options...
MagicMikeZ32 Posted February 18, 2016 Share Posted February 18, 2016 The old US dyno chestnut. Been having this arguement on the zed forums for years. 1 Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685348 Share on other sites More sharing options...
XKLABA Posted February 18, 2016 Share Posted February 18, 2016 You talking about raising the fuel pressure? Its already at 58psi. Figure another 25psi when under full boost you are looking at 83psi rail pressure. Not sure on cr No, I mean 58psi base is already 15odd psi higher then the base we usually see, mine is at 50psi which is already high then normalYou don't know what the compression ratio is ? Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685352 Share on other sites More sharing options...
mr skidz Posted February 18, 2016 Share Posted February 18, 2016 What is the smallest id of your exhaust system? Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685356 Share on other sites More sharing options...
Jc052685 Posted February 18, 2016 Author Share Posted February 18, 2016 What is the smallest id of your exhaust system? 3" I believe.... And its Rickys car, just so there is no confusion. No, I mean 58psi base is already 15odd psi higher then the base we usually see, mine is at 50psi which is already high then normal You don't know what the compression ratio is ? I did not build the motor so I do not know the specifics. most modern fuel systems run 58 or so psi. That is where we normally run things. Had this car at 43.5psi in order to help with pump gas drivability but we had to turn it up. The ID1000's are rated at about 1150cc/min at 58psi. Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685360 Share on other sites More sharing options...
mr skidz Posted February 18, 2016 Share Posted February 18, 2016 3" That won't be anywhere near enough to get you 700 wheel Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685364 Share on other sites More sharing options...
Jc052685 Posted February 18, 2016 Author Share Posted February 18, 2016 3" That won't be anywhere near enough to get you 700 wheel Odd..... I have made over 900whp on a 3" exhaust. Even that much must cover our apparent over zealous dynos. Link to comment https://www.sau.com.au/forums/topic/463036-rb-2860-5-highest-hp/page/2/#findComment-7685367 Share on other sites More sharing options...
