It was.
Linear, quick to fall back into its stride. I would 100000% prefer that than a set of -5's (let alone a set is RS's) on a stock engine. Makes me very curious to see what a 3582R would do on the same setup, being smaller.
That was an old dinosaur garrett Z, open scroll, single gate setup.
The Zs work well don't they.
[emoji2] [emoji2] [emoji2]
Don't know what it is with the 35s but they don't seem to come back on as quick in between gear changes, where dyno sheets makes them look better than what they are in my experience.
Its good to see u experienced the Z first hand, dynos tend to lie about a lot of things, but its a fun turbo that's for sure.
Edited by XGTRX
Yet to see a GTW result that is half decent.
I would assume twin scroll, billet compressor wheel and ball bearings would make some difference compared to the dirty T04z you tested?
The old T04z dynos never looked any good really. People actually use to look at that and stay with the twins.
Edited by s2d4
Old Z with a newer style billet compressor with a bit of cleaning up comes on 300 or so earlier. Pretty much what a GTW does, yet people always claim more response, like 500 rpm, yet to see it though.
Because most GTR owners run those T04z in single scroll.
To really harness any motor vs. turbo application is to go twin scroll to reduce back pressure on each pulse as well as rely on scavenging.
The more the motor breathes, the more torque and power it will make. Simple combustion engines 101.
I got into this car expecting the worst. Got out of it with a smile on my face.
I'm not shy to express my hate for 2.6L's. They suck. But I'd rather a 2.6L open scroll, dirty old Dinosaur T04Z than a 2.8L with RS's as much as I hate to say it.
Call it what you will. I'm VERY critical of a setup.
Garrett Zs are ball bearing
I wasn't having a go nor do I like RS's.
Was just saying that you would like the gtw more than the old z, dyno or no dyno considering you like the z and that generally has not so nice dyno curve.
Well, the same can be said about the GT vs GTX. And the jury is still out on those as they take a shit load of boost to reap the benefits. Yet to see a gtw impress on an RB in the real world. As piggaz found out the old BB Zs aren't as bad as people make them out to be and their performance aren't really reflected on a 4th gear WOT run on a dyno sheet. As with so many perceived laggy dyno sheets, the real world says different.
  • Like 1
If I could draw a comparison.
The low end fell between a -9 and a -5, yet made 450 kW. This was the most basic jurassic park setup there is. A proper twin scroll manifold, twin gates, two scroll ass end housing would have made it better no doubt!
"Twins for response" is a little upsetting when a dinosaur open scroll Z punches hell out of -5's on an equivalent engine.
Yeah, I wasn't disagreeing with you guys.
No idea what started the shit storm.
Pretty sure that's what I was saying.
Fairly certain they didn't used to be and can still be ordered without the ball bearing, no idea how old of a Z we are talking about though.
They were BB from about 10+ years ago, old tech with BB cartridge.
No shit storm, just a discussion, all good. Edited by XGTRX
  • Like 1
Don't you have 04z setup in yours?
If so, is it modern 04 or? I'm curious now lol
As much as you say you don't we all know you love the little 2.6
Dual Ball Bearing Garrett To4Z . 700-750HP flow potential.
Compressor wheel diameter is 84mm exd. / 66.7mm ind. (63trim) Compressor housing is .70 A/R has a 4" inlet and 2.5" outlet slip on connection.
T4 Turbine housing divided A/R .84 entry, all with standard 3" V-band discharge.
Turbine
-Wheel: 74.2mm w/ 76 trim
-T4 Divided Housing A/R .84
Compressor
-Wheel: 84.0mm exd./66.7mm ind w/ 63 trim
-Housing: 0.70 A/R
Edited by XGTRX
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
